Old 07-21-2004, 12:07 AM   #1
walkintall49
What primer ?
Having my 1972 4door bead blasted tomorrow.What primer should I use?Is there any kind of preservative I should put on the metal? Thanbks for your help.
walkintall49 is offline   Reply With Quote
Old 07-21-2004, 12:39 AM   #2
bigbluthng
bigbluthng's Avatar
a good quality epoxy primer is what you need. use a bare metal prep solutution before you spray anything.
bigbluthng is offline   Reply With Quote
Old 07-21-2004, 12:56 AM   #3
Ogier
Chopper/Painter
Ogier's Avatar
Exclamation
A good etching primer will save you the step of preping the metal...
Good luck.
I will be doing the same thing to my truck hear soon.
Now if I could just decide between kandy brandywine over a gold base or stark white with ghost flames....
Ogier
Ogier is offline   Reply With Quote
Old 07-21-2004, 03:11 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Here's a good article by Martin SR, he's been in the auto paint busiess for years and flat knows his stuff.
http://www.myoldtruck.com/modules.ph...showpage&pid=7
There are 3 pages in the article.
His best advice is to stick to one brand of products for the entire painting process. Everything from metal prep cleaner to clear coat.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
