Old 07-21-2004, 12:46 AM   #1
1968GMC
love my truck
1968GMC's Avatar
horn at steering problems
I am not shure if I'm missing a wire or something. look at the pics and tell me if it looks allrite.
1968GMC is offline   Reply With Quote
Old 07-21-2004, 12:47 AM   #2
1968GMC
love my truck
1968GMC's Avatar
is there supposed to have a wire on the first pic in that litle hole?
Old 07-21-2004, 06:18 AM   #3
JimKshortstep4x4
Smile
You have everything right for the horn to work. The "spring" is actually part of the horn contact. When you press on the horn the spring depresses and contacts the steering wheel grounding the horn relay, (causing the horn to blow).
The "spring" looks pretty rusty and may need to be cleaned up at the contact area, (contact area is the inner lower lip). Make sure the steering wheel is clean where the "spring" contacts it.
Jim
Old 07-21-2004, 08:08 PM   #4
franko72
Franko72
franko72's Avatar
My spring plate was flexed (bowed ) when I installed it.I put it in one way and it didnt work. I removed it and flipped it over , re installed it and it worked fine .pics look like everything is there. make sure you are getting good contact on parts
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 07-21-2004, 08:42 PM   #5
bucket
bucket's Avatar
i recently had same problem. rubbing steel wool on the contact parts solved the problem.
bucket is offline   Reply With Quote
