Old 07-21-2004, 01:10 PM   #1
72c10step
WHYBYNU when old will do?
72c10step's Avatar
What type of radiator cap should I use?
I am going to finally put my coolant overflow tank on my 72 Chevy pretty soon, and I remember a post from last year that said you had to run a certain type of radiator cap to let the system work properly with it. I've been searching for the post, but can't find it anywhere. I want to get the new cap when I go to the parts store tonight, so what type do I need, or to make it easier, fill in the blank: I need a radiator cap for a 19__ Chevy Truck.
Thanks,
Jay
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 07-21-2004, 01:34 PM   #2
71Chev
71Chev's Avatar
85
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 07-21-2004, 01:44 PM   #3
StingRay
StingRay's Avatar
All you really need is an 11 lb cap for your rad. Anything over that is really overkill as the engine will be overheating before the coolant is boiling anyway. At only 11psi it is way easier on your rad.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-21-2004, 03:15 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It has to have a double seal, for a closed system. If it isn't a double seal cap, the excess will be siphoned off to the recovery tank, but won't be returned to the radiator.
Member Nr. 2770
Old 07-21-2004, 03:48 PM   #5
cdowns
cdowns's Avatar
chrome caps keep them cooler!!!
depends what type of system you're using?? if just the standard 72system then you need a rad cap for a 72 and like he said 11-12lbs is about right
Old 07-21-2004, 04:50 PM   #6
OhioDan
OhioDan's Avatar
As was said before, just tell them you want a cap for a "closed" system.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 07-21-2004, 05:28 PM   #7
71Chev
71Chev's Avatar
or for a 1985 chevy truck to make it easy.
Old 07-21-2004, 06:38 PM   #8
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Not only that, but it greatly reduces the chances of blowing out your heater coil. I wouldn't run more than 12 lbs on these old trucks for that reason alone.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 07-22-2004, 04:12 PM   #9
72c10step
72c10step's Avatar
Thanks guys, I'll put it on the list of parts to get next time I go to the parts store. Looks like I'll be spending quite a bit there .
-1984 Jeep CJ7
-2003 Honda 300ex
Old 07-22-2004, 04:41 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You'd be hard pressed to find a non closed system radiator cap at any parts store this side of Dry Crotch Nowheresville. They are somewhat obsolete nowdays.
All the parts guy is going to want to know is how many PSI do you want.
