driving is in my blood
part throttle stumble?
My engine has a stumble under part throttle when it gets hot around here and I can't tell why. Its been tuned correctly and the plugs look good, also my a/f gauge says the ratio is good.
The only time it acts up is when going from a stop and you just get on the gas, it stumbles. Once your going theres no problem, and if you start from a stop and give it a good amount of pedal then theres no problem. Any ideas?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
what kind of carb do you have.
Its a carter 600cfm with no choke. It has a HEI with 14* initial hooked up to ported vaccum.
Tom, are you running an egr on that engine?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
no egr
