Keep On Truckin'
Time to cut a center vent hole in a non-A/C dash.Trying to find a picture of the center A/C vent hole with the vent removed. Also, need dimensions of hole. Thanks
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
Southern Bowties
How bout 1 1/4" x 5"
There's a pic taken from the pasg side on my www button-"before" pics, if that will help. You're probly lookin for a pic taken from the center, which I dont have. hth
1972 Cheyenne 350/350 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
here's a couple pic.'s
![]() ![]() Vent studs. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
![]() Join Date: Dec 2003
This is what mine looks like
1969 Chevy SB Truck under construction hopefully will be done early next year! Will be posting pics soon. |
Keep On Truckin'
Thanks guys. I need to cut this hole in mine. Can someone give me the measurements of the main center hole and the little slots on each side ?
Here you go, I hope these help. It was tough to hold the camera still enough to get those small numbers
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Here are the measurements I got.
Total hole with edge slots 5 3/4 across 1 5/16 tall slot on edges seperately 5/8 tall 5/16 deep Hopefully that is easy to understand ![]()
#8 | |
Keep On Truckin'
Thank you very much, that's exactly what I need.
![]() Quote:
