Old 07-22-2004, 01:08 AM   #1
Scrubby
Check out GMTrucks.org
Clutch fan question
With it being so hot outside, I have noticed that my 71 burb has been running hot at stop lights. This has me suspecting the clutch fan. When I got home today, and the engine was hot, I got out, popped the hood, and tried to spin the fan. It spun fairly easily with just a little bit of drag. Now as I understand it, when the engine is warm, the clutch should not spin at all because it should lock up on the shaft and pull air thorugh the radiator. Do I have this right and it is time for a new clutch fan or maybe a fixed fan?
Scrubby is offline   Reply With Quote
Old 07-22-2004, 01:18 AM   #2
68 Suburban
68 Suburban's Avatar
These two post might help you
http://67-72chevytrucks.com/vboard/s...ght=clutch+fan
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 07-23-2004, 09:08 AM   #3
rage'nrat638
rage'nrat638's Avatar
I HAVE JUST THE FIXED FAN YOU WANT.....I AM RUNNING ONE ON MY OWN TRUCK AND IT KICK BUTT....
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2485283571
rage'nrat638 is offline   Reply With Quote
Old 07-23-2004, 09:41 AM   #4
dubie
dubie's Avatar
I took my clutch fan off when it spun freely and replaced it with a fixed fan that bolts right thru the upper pulley and spins all the time the pulley does
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-23-2004, 12:48 PM   #5
jorgensensc
jorgensensc's Avatar
Sorry to steal the thread, but I've got a question.
I installed a Vintage A.C. system in the truck and the dealer (who also installs these systems) suggested that I get rid of my bolt on fan and go with a clutch fan. He said at stop lights the clutch fan pushes more air (because of blade pitch), but on the freeway freespins so it doesn't have that annoying howling sound. He said I coul get a diferent pitch bolt on blade, but on the highway it would be annoyingly load. Does anyone here have any good suggestions or input? Can anyone suggest what year and make to get a good clutch fan out of? Sorry to hijack, but you reminded me of what I need to do.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-23-2004, 02:16 PM   #6
Pops
I have a stock cluch fan on my '73 and I have no problems in traffic or the open road. I live in the Los Angeles area and the freeways become parking lots some times.
67 long bed step side/future fuel injected 502
73 Cheyenne super20/ fuel injected 454
Pops is offline   Reply With Quote
