Old 07-22-2004, 11:40 AM   #1
cochino12
It followed me home?
cochino12's Avatar
t-case drop
What do I need to drop my t-case? I realize I need some longer bolts but what do I use to space it? and do I need a special grade bolt, or will some bolts from home depot work? 1" is the most I should drop it right? Thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-22-2004, 11:42 AM   #2
CHEVYJEFF
CHEVYJEFF's Avatar
i just used the stock spacers and bolts that were in there already. about 1" long. Remeber to check that tranny mount too
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 07-22-2004, 11:46 AM   #3
cochino12
cochino12's Avatar
I suppose if I actually remembered what it all looked like that would make sense, but I am a little . You dont have any pics do you?
Oh and the tranny mount is good, the tranny is slipping though. Time for a 700r I guess.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-22-2004, 12:01 PM   #4
CHEVYJEFF
CHEVYJEFF's Avatar
try this it has the info on tc drop and the grinding of the front shaft cv joint which you will neeed to do also
http://rough.roughcountry.com/145S.pdf
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 07-22-2004, 12:09 PM   #5
cochino12
cochino12's Avatar
great info, thanks
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-22-2004, 02:33 PM   #6
cochino12
cochino12's Avatar
How long did all this take you?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-22-2004, 04:37 PM   #7
drink2mny
drink2mny's Avatar
I can tell ya I dropped the one on my '86 blazer.. used pipe fittings for spacers 1".. never needed to grind the cv on the front driveline..
I will however hint around to sandwiching the frame where the bolts go through.
I started to crack my frame from flexing and torque..
so I took steel plates 1/4 or so and sandwiched the frame ..then just tackweled them in place..
never had a problem since..
Support The Board
drink2mny is offline   Reply With Quote
