Old 04-05-2002, 10:19 AM   #1
Cal69Chevy
Cal69Chevy's Avatar
Post How to completely remove speedometer?
thanks for the replies on the knob and spedo cable...but my odometer isn't working and I'd like to fix that as well. how do you remove the spedo complete from the cluster?
I was successful in removing the cover from the dash but everything is attached to it and i could only move it an inch or so from the dash(there's little or no slack in the cables/wires)...how are all the guages attached to it?
thanks in advance...you guys have been an awsome source of help thus far!
ken
'69 Chevy, 4X4-SB 350 TBI-TH350 Trans-205 Transfer Case-Dana 44 Front-14 Bolt Rear-Front Disc Brakes-Factory A/C-P/S
Ken's '69 Page
Cal69Chevy is offline   Reply With Quote
Old 04-05-2002, 10:25 AM   #2
69 longhorn
Post
Everything should be printed circuit,except the oil gauge,will have a line to it. Un hook the batterey first,then you should find a plug(high on the RH side of the panel). It has a prong on ea side that you need to depress to un hook it. Once you remove the complete panel,you can turn it over & dis mantle it from the back side. Good luck....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
