Can't stop spending
I am looking for help identifying this BB a/c bracket. The motor in the picture is most likely a 402 BB, and it has an Edelbrock intake mounted on it. It is my understanding that the original a/c brackets for the 71'-72' 402's had a bracket that went over the top of the valve cover and attached/bolted to the intake. I am interested in the a/c bracket in the picture, because I also want to run an Edelbrock intake (which means that I can't use the factory brackets).
Anybody have any ideas. Obviously, I don't know a bunch about these trucks, so any help would be greatly appreciated. Thanks! |
![]() Join Date: Apr 2000
Heres a pic to help. If your not running tall covers I dont see why you couldnt use it.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
Can't stop spending
Are we talking about the same?
Thanks for the pick. I really appreciate it. I have a question, though. Is that the stock intake, or an aftermarket? It looks stock to me. If it is stock, then that is not quite what I am looking for.
I am looking for brackets that would allow me to run factory a/c with an Edelbrock intake (just like the one in the pic I posted). As can be seen in my pic, there is no bracket that extends over the top of the valve cover. So, I am trying to figure out how the guy in the pic mounted his compressor. Thanks again. |
Its a cast iron hi-rise intake that came from a 396 in a Chevell. The original was a low-rise. The bracket is 2 piecses.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters Last edited by 1-PU70; 07-22-2004 at 04:20 PM. |
I'm running an Edelbrock Performer intake and have the rear bracket as shown in 1-PU70's picture. As long as your not running tall valve covers the bracket will work just fine. Only issue is you will need bolts that are a bit longer. Think it was an extra 1/4" but it's been awhile.
From the looks of the original picture, the rear of the a/c doesn't appear to have any support whatsoever. You can use the original brackets with an aftermarket intake, you may have to hit the bracket with a grinder to clear the runners, but it can be used.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
I need one of those Bracketts!
![]() I apoligize for busting in on this! I posted on hear the same day asking about these and if anyone had one they wanted to part with. Unfortunently No one replied. By chance do any of you have an exrta one of the bracketts that go from the A/C over to the intake Manifold. I have the one that is mounted on the intake That it would attach to. Just a Gamble. Felt like rolling the Dice today. Thanks and nice Pics. Regards, Longhorn70gmc ![]()
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! Last edited by longhorn70gmc; 07-26-2004 at 12:01 PM. |
