Old 07-22-2004, 04:14 PM   #1
racedvl
racedvl's Avatar
Hhhhmmmm, brake hose problems, with swapping rearends. . . . .
OK, I have a 1969 SWB C10. I am getting ready to swap in a 1972 rear end to get ready for my soon comming front disk swap. As I was getting ready to run the new brake lines to the wheel cylinders, I see that the rear brake rubber hose is diffrent from my 69 style. I looked in the Raybestos book, and sure as heck, it is a diffrent part number.
SO I guess what I need is a picture of how this rear brake hose is set-up on a 72 truck, so I can finish running my steel lines.
Here is what I'm up agaist. Thanks for any, and all help.
racedvl is offline   Reply With Quote
Old 07-22-2004, 04:46 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
I'm not sure if I'm understanding the question but, the "L" shaped bracket bolted to the pumpkin cover in the last pic is where the 72 rubber hose attaches and your hard lines to the wheel cylinders tee off that.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-22-2004, 05:14 PM   #3
racedvl
racedvl's Avatar
Ok, do I have the bracket mounted correctly in my last picture? The picture was taken with the "top" of the rearend facing me in the picture.
Can anyone with a 71/72 C10 get me a picture of your rearend? How your current lines are ran, and a side shot of where the rear brake hose attaches? Thanks.
Old 07-22-2004, 05:23 PM   #4
Mixup
brake hose
My 69 has that " L" bracket mounted on the rear end cover.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 07-22-2004, 06:14 PM   #5
fast71
Drive it like U stole it
fast71's Avatar
I put a 72 rear end in my 71 and had the same problem you have. The only difference is my bracket is on the front side of the axle tube where your is on the rear of the tube . I took a grinder and grinded the welds and removed the bracket and welded it to the 72 rear end.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 07-22-2004, 10:11 PM   #6
racedvl
racedvl's Avatar
Ttt.
Old 07-22-2004, 11:22 PM   #7
grayw0lf
Give into the temptation. Buy a MIG welder. Remove those horrible old U-bolts & weld it up all nice & pretty (& permanent). You will be glad you did. I will be doing my daily driver this weekend. I have many splices from cutting out the ugly heat creating thingy.
I welded my first muffler on last night. My neighbor's was completely severed from rot. Piece of cake. Ok, it was old & RUSTY & nasty from old welds, but welded decently & braced nicely. Should last many moons.
-Wolf.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 07-23-2004, 09:50 AM   #8
racedvl
racedvl's Avatar
Ttt. . . .
