07-22-2004, 09:36 PM | #1 |
yeller
What does this do?
This was attached to the end of my old speedo cable. It mounts between the trans and cable itself. What does it do? It was formally attached to the th350 trans that was in my '73.
I purchased a new cable in order to install my Autometer speedometer, do I need to use this or simply screw my new cable to the transmission? Thanks for the help.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
07-22-2004, 09:45 PM | #2 |
Professional Grade
I think that has something to do with adjusting the speedo cable ratio...
My SM465 has one just like it attached to it...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
07-22-2004, 10:44 PM | #3 |
You get what you pay for
I'm not exactly sure what that is. But to answer your question, no, you don't use this part with a 700R4 and the Autometer speedo.
Mike 1985 Chevy C-10 |
07-22-2004, 10:56 PM | #4 |
california fill
it changes the speed of the speedo input cable so your speedometer reads accurate... turn the input of it exact one turn and the output will be slightly different
pc |
07-22-2004, 11:05 PM | #5 |
Hrmm thats interesting, i have the exact same thing on my speedo and it reads wrong.
Maybe it needs adjusting?
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
07-22-2004, 11:07 PM | #6 | |
yeller
Thanks again everyone.
07-22-2004, 11:14 PM | #7 |
Gentleman Jim Driver
To expand a little...
I don't know why GM didn't just put the right gears in the tranny for the speedo, but three of my six trucks (at least, I don't know that I've looked at them all...) had these factory. They are just two gears in a case to change the speed of the speedo cable compared to the gear in the adapter installed in the transmission. GM offers enough drive and driven gears to be installed on the transmission output shaft and in the cable adapter to eliminate these external gear boxes, which is what I have been systematically doing on my trucks... - I do understand that Jeff is going to an electronic speedo and this is all unnecessary for him... Joe |
