Old 07-22-2004, 10:58 PM   #1
chevyfan420
Question Lower A Arms ?????
I had my coil spring drop down through the spring pocket on my 79 1/2ton today. I have an 86 parts truck sitting. i plan to take the one arm off the 86 and put it on my 79. Does anyone know if the arms are identicle or not? I figure they are but don't know for sure. Also, I read up on the procedure, do I have to replace the two u-bolts that hold the arm to the frame or can i re-use them? Can anyone give any advice before I start tearing it apart tomorrow?
80 Chevy K10 350/350turbo
86 Chevy 1/2 ton shorty project truck
79 Chevy 1/2ton 350/350turbo
not much to look at... ***Retired***
97 Chevy C1500 4.3/5 speed.....daily driver
chevyfan420 is offline   Reply With Quote
Old 07-22-2004, 11:03 PM   #2
Jonboy
Slots go on anything!
The arms will interchange, providing both trucks are 1/2 ton. You don't have to replace the U-bolts, you can reuse the best of the ones you have. Make sure the dowel pins on the cradle are lined up correctly with the holes on the shaft in the A-arm, and you are set. You might want to check teh ball joints and bushings while you are there.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-22-2004, 11:51 PM   #3
chevyfan420
ball joints and bushings? what bushings are you referring to?
Old 07-23-2004, 12:15 AM   #4
Jonboy
The large rubber ones that flex where the arms pivot.
