Old 07-22-2004, 11:33 PM   #1
Ogier
Chopper/Painter
Ogier's Avatar
Lightbulb What Axle do I have?
Greetings all,
I am going to regear my rearend in my '69 chev C-20 and need to know what axle I have. It is the one with the center pumpkin that drops out the front when you remove the axleshafts.
I think it currently has a 5.13 gear ratio in it and I want to go with a 3.23ish gearing.
Thanks in advance.
Ogier
Ogier is offline   Reply With Quote
Old 07-23-2004, 02:14 AM   #2
Ogier
Chopper/Painter
Ogier's Avatar
Exclamation
*bump*
here are pictures of the front and back of the axle.
Ogier
Old 07-23-2004, 04:17 AM   #3
texnician01
texnician01's Avatar
looks like maybe an eaton to me but i'm not all that good on 3/4 tons.
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 07-23-2004, 05:52 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
yep that's what's called the eaton/corperate axle also known as H052 (3/4) or H072 (1 ton) rear. It was replaced by the 14 bolt full float axle in 1973. The best(highest) gear ratio you'll find will be 4.10s. 3.90s were supposedly available from the aftermarket. Do a search on H052 or H072.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-24-2004, 12:43 AM   #5
Ogier
Chopper/Painter
Ogier's Avatar
Lightbulb
Ok, Now that I have the axle positively identified as an Eaton. I would like to swap in a 12-14bolt 3/4T axle in it's place. What vehicles should I look for this under. I don't want to have to cut and weld on mounting hardware. I want a direct bolt in.
I believe that I will have to shorten the driveline a bit to do this swap and am prepared to do so.
Thanks again in advance,
Ogier
Old 07-24-2004, 01:37 AM   #6
Pont
I need another Barley Pop
Pont's Avatar
Ogier, just wanted to welcome you to the board from a neighbor. I'm in GP
Pont
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 07-24-2004, 10:35 AM   #7
Ogier
Chopper/Painter
Ogier's Avatar
Thanks.
Ogier
Pont
Old 07-24-2004, 02:18 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Whether or not you keep the rear that you have, here's some info from my '69 Truck Data book (dealer item). The stock gears for your truck should be 4.10's. That's the standard ratio with any engine except the 250 6-cyl. There's a 4.57 available, but only with the 250. Look for Option number H20 or HB8.
Member Nr. 2770
Old 07-24-2004, 03:37 PM   #9
Ogier
Chopper/Painter
Ogier's Avatar
I would like to get down to about 3.30ish I think. So, I believe that I need a 12-14bolt 3/4 tonne axle to do this rather than the eaton.
Ogier
Old 07-24-2004, 04:31 PM   #10
1969 GMC
1969 GMC's Avatar
5.14 were an option with the Eaton axle. IIRC, the 14 bolt can only go down to 3.73, but the dana 70 (similar to the Eaton and 14b) can go down to 3.07. Or, you could always swap in lighter axles, like the 12 bolt.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-24-2004, 10:39 PM   #11
Ogier
Chopper/Painter
Ogier's Avatar
A 12-bolt would probably be just fine. I don't abuse my rigs.
Ogier
