Old 07-23-2004, 08:47 AM   #1
Dean
Dean's Avatar
Green K20 had first breakdown.....
Drove the truck up to the drive thru to get some dinner late last night. No problems up and back, but just as I was getting ready to pull in the shop, it died. It was just like you turned the key off with no funny noises. I'm getting fuel but it looks like the spark is a very weak. I'm wondering if something happened to my HEI, cap, coil, etc. Looks like I know what I will be doing tonight.... It got dark on me last night so it is still setting outside. Actually that was the first night it has ever sat outside...lol
Dean is offline   Reply With Quote
Old 07-23-2004, 08:53 AM   #2
dubie
dubie's Avatar
yeah sounds like the coil is gone bud.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-23-2004, 09:00 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
HEI module, spend the extra $20 or so and get the GM one. We bought a NAPA special and it lasted about 2 months. The GM version hasn't failed us (yet). And yes we applied the heat dissapating grease with both.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-23-2004, 09:36 AM   #4
Mudder
Mudder's Avatar
Could be a wire on it (distributor), has come loose. Mine did that going down the highway at about 70mph one night........
Mudder is offline   Reply With Quote
Old 07-23-2004, 10:00 AM   #5
racedvl
racedvl's Avatar
I had the same thing happen, I ended up having a broken wire inside the dizzy. I forgot what it is called, but it is the round peice, with the 8 points on it.
racedvl is offline   Reply With Quote
Old 07-23-2004, 11:57 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Nooooooooooooo! not the green truck!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-23-2004, 02:34 PM   #7
StingRay
StingRay's Avatar
Could be the module or the pick up coil wire. The pick up coil moves with vacuum advance and the wires to it will break over time. It's a given. As for the module use a GM part or get yourself an MSD.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-23-2004, 02:50 PM   #8
dubie
dubie's Avatar
wouldn't the power cut in and out a bit if it was the module? I had that happen on my 80 Grand Prix. After running it for a while, you would accelerate and the power would cut out until you let off the gas and then would eventually stall the car
Old 07-23-2004, 03:08 PM   #9
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
StingRay has it correct, it's either the brick or the pickup coil. Spend the extra money and buy the GM...been down that road. Most of the chain auto supply places will check the module for you to see if it's bad. If you have an ohmeter you can check the pickup coil to see if it's good. Pull the plug off the module that has the green and yellow wires and measure between the pins on the plug. It should measure between 140-160 ohms. Good luck and you have a very sharp truck.
Dave
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 07-23-2004, 08:02 PM   #10
Dean
Dean's Avatar
Truck is back running again and in the garage. I removed the Accel coil and one of the little wires was pinched and the bare wire was touching the plates. I was going to tape them up, but just decided to go back with the GM coil since the rest of the engine is looking original.
The truck actually started right up when I got home which surprised me. I was running up and down the road testing it when the thing died again. My brother pulled me home with the Kubota.
Thanks for all the suggestions! I've got 154 miles on it now.
Also noticed that I have to pull off one of the back drums. The brake shoes pin has came loose on one. That explains the sound I've been hearing....lol. Such a pain to pull the drums off the Corp rearend............sounds like a project for the morning.
Old 07-25-2004, 07:28 PM   #11
Dean
Dean's Avatar
Well............I thought I had it fixed last night.. It quit on me again this morning on my road. Another trip back to my shop on the tow strap. I changed HEI modules, condensor, cap and coil with no luck. I finally pulled the distributor and put another on in which seemed to fix the problem. I'm guessing the pickup in the distributor is bad. Must also be triggered by heat. Anyone had this problem? It is tough reaching the distributor on a 4x4 with a lift on top of that.
I drove it up and down my road for 30 minutes with no problem so I still have my fingers crossed.
