a few a/c questions ?
Fan speed only one speed. It is about medium speed. The compressor cuts off when you go in the high position. Is this a switch problem ? Also, The middle lever on the dash has a piece missing that presses down the switch to cut on the compressor( ive got the switch bypassed to get it to run). Last question: hoses on water pump to heater core: which hose is supply to core ? the one on the water pump or the one on the intake manifold ?
guypm 1971 SWB Fleetside/350 performer rpm heads &intake/ holley 750dp/1.5roller rockers/MSD6a/700r4 1650stall/one piece driveshaft/3.73 open/dynomax ceramic coated headers/3chamber flowmasters/ |
