Old 07-23-2004, 03:50 PM   #1
wedgemon
wedgemon's Avatar
Board recommendations -
Need some advice as to what to add to my truck.
1980 Scottsdale 4x4, 350, 4v Edel 1406, RV Cam,No egr. That's it so far.
Advice items:
- Headers: Shorty or Long (I DO want the low end torque!)
- Dual Exhaust or Cat back. (Cat will likely come off)
- Best sounding mufflers. (quiet at cruise and throaty at WOT)
- Intake (looking at Edelbrocks)
Any other items that "Bolt On" for just a little more street excitement and the occasional GRUDGE at the local race track. (some Ford trucks out here think they're Chevy's)
Maybe: Ignition (MSD etc), Elec Fans, Jetting, Blower, Turbo, NOS. Good stiff tailwind...
Thanks - Wedgemon
*Mountainous Surf - The Wedge!
wedgemon is offline   Reply With Quote
Old 07-23-2004, 04:10 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Headers: Hooker Competition headers (ceramic coated would be better but more money)
Exhaust: Dual 2-2.25 pipes, Dynomax supper turbo mufflers
Intake: Probably an Edelbrock RPM its better than the performer and doesn't take that much low end out of the engine. Some may disagree with the RV cam though not being hardly more than stock with that RPM manifold.
Would recommend being able to find a distributor shop and have them setup the advance curve for your engine. They use a machine to match different combinations on springs to tailor an advance curve for your vehicle. Its also a DIY thing it you wanted but it will take a lot of gas, trail and error.
Have you looked at the spark plug to read them? What do they look like?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-23-2004, 04:17 PM   #3
wedgemon
wedgemon's Avatar
Thanks for the response,
The plugs were slightly carboned. But, I've yet to "Initially tune" the 1406. I just slapped it on and it out ran the Q jet. So I have'nt messed with it yet. But, it is leaving spots on the driveway. (to my wifes dismay!)
Also, your exhaust ideas sound great, but is that dual or ??
Thanks - Wedgemon
Old 07-23-2004, 04:22 PM   #4
MylilBowTie
Right turn Clyde
Yes, that would be a dual exhaust setup I was talking about. It would also be nice to have a crossover pipe but with the 4x4 transfer case it makes it more difficult to do.
Ohh yeah, Welcome to the Board!!!
Old 07-23-2004, 04:22 PM   #5
wedgemon
wedgemon's Avatar
I Need to re read that! It's dual. Tx - Wedgemon
Old 07-23-2004, 04:23 PM   #6
MylilBowTie
Right turn Clyde
Do you know where the oil leak is coming from?
Old 07-26-2004, 11:10 AM   #7
wedgemon
wedgemon's Avatar
Oil Leak???
Not an oil leak. Blows out exhaust. I suspect I'm a little rich with the "Un-Tuned" 1406 and the un needed catalytic. And I'm eather blowing residual carbon fron the exh pipes or I've got rich build up in the cat - 'cos its a little wet OUT THE EXHAUST.
Wedgemon
Old 07-26-2004, 04:17 PM   #8
MylilBowTie
Right turn Clyde
I was thinking oil leaks, not tire(s) marks for some reason. 1406 should be good now but when they better exhuast upgrade is done Im sure it will be on the leaner side. It could be already with your cam. It would be a good idea to find out why the spark plugs are getting fouled dry or wet (gas/oil). Could be valve seals, valve guides, intake manifold gasket, stuff along that line. It will help in getting the 1406 jetting right a lot easier.
