Old 07-23-2004, 06:09 PM   #1
nitor
Too many projects
nitor's Avatar
73 - 87 spindles
I know I've seen something about this in the past but I can't remember. Does anyone know if the spindles from a half ton 73-87 fit on a 67-70 half ton? I have access to a 85 GMC 1500. I think the cross member is bent, but I know the spindles are OK.
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 07-23-2004, 08:31 PM   #2
Harold Shepard
They will fitr but you have to change the ball joints and the outer tie rod ends of your truck become the inners and 73 up tie rod ends go to the outside, takes a different sleeve to connect (I think) the two together. Hope it helps you out
Harold Shepard is offline   Reply With Quote
Old 07-23-2004, 09:53 PM   #3
crazy longhorn
Fabricate till you "puke"
Yup, upper & lower balljoints, & outer tierod ends.....on your 67-70, there is not enough info on the centerlink. You might opt for the centerlink off the donor truck, & figure tie rod assy (inners, outers, & sleeves). if you look 71 up on the 1/2 tons, the centerlink should work.....just remember that the upper ball joint, &the outer tierod end is different 73 on ,for the 1/2 tons vs the 71-72 pcs. best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-25-2004, 06:41 AM   #4
nitor
Too many projects
nitor's Avatar
Sorry, you confused me. What ball joints do I need if I have to change them out? Do I use the year of the donor? Then, what tie rod ends? 71-72 or the year of the donor again? Longhorn you're also saying that I need to change out the centerlink because it may not be long enough?
Jim
'04 Chevrolet Astro
Old 07-25-2004, 08:05 AM   #5
MOTHERTRUCKERS
Take the spindles,rotors,calipers,hoses, tierods,centerlink,draglink and pittman arm off the donor truck and get 73-87 upper and lower balljoints.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 07-25-2004, 10:59 AM   #6
crazy longhorn
Jim, you just need to order the balljoints, tierods ,ect for the yr of the spindle you use. the taper on the balljoints differ from 67-70, vs 71-72. 73-87 also changed the taper on the upper balljoint, & the outer tierod end...as compaired the the 71-72 pcs. As MOTHER TRUCKERS said, peel it all off 1 truck(it will save a lot of confusion). Best of luck,crazyL
Old 07-25-2004, 04:48 PM   #7
nitor
Too many projects
nitor's Avatar
Thanks guys. I'll see what I can do.
Jim
'04 Chevrolet Astro
Old 08-01-2004, 12:14 PM   #8
lloyd k
lloyd k's Avatar
73-87 spindles
yoll want to use your original centerlink,the longest one,itll bind in a lowered truck,went thru all of that with mine
lloyd k is offline   Reply With Quote
