Old 07-24-2004, 05:49 PM   #1
lolife99
67-72 parts collector,…
lolife99's Avatar
'71-'72 centerlink?
I need the center link for my '71 2wd Blazer. I am rebuilding the front end and I have all the parts except the center link. (the thing that the inner tie rods bolt to.) It's not available from gm or my local parts house. Any ideas? Thanks, lolife.
Old 07-24-2004, 08:25 PM   #2
XXL
Señor Member
XXL's Avatar
It's not available as a new repro from anywhere... so you're probably going to have to scavenge the junkyards. Or, if you want to pay an arm and a leg, call Early Classics. They have a bunch in their inventory so they can gouge you when you really need one.
XXL is offline   Reply With Quote
Old 07-24-2004, 09:02 PM   #3
lolife99
lolife99's Avatar
Thanks. I will start searching. Anyone on here have one???
Old 07-24-2004, 10:05 PM   #4
crazy longhorn
Fabricate till you "puke"
71 -up should work on the 1/2 tons, in other words, the cenetrlink from the next gen truck should fit try shooting for a mid 70's 1/2 ton (73 on, with power steering, if that is what you have). some of the manual boxes had a different sized hole for the pitman arm, & nobody seems to have an interchange.....boneyard part only.....& they cant tell you what fits! best of luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-25-2004, 08:10 AM   #5
MOTHERTRUCKERS
I have 71-2 p/steering centerlinks in stock cleaned up checked and hanging on the wall 40.00 + shipping.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 07-26-2004, 12:25 PM   #6
lolife99
lolife99's Avatar
how much to ship to 65251 zip code?
Old 07-26-2004, 12:53 PM   #7
SCOTI
SCOTI's Avatar
My experience was you would need to use the 73-up tie rods if you use the 73-up center link (they are different). I assumed they were the same & was suprised when I learned different while doing my 68 beaters disc conversion. I just swapped for new 73-up inners since it's much easier to find the later model stuff in the wrecking yards.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-27-2004, 09:12 AM   #8
MOTHERTRUCKERS
8.00 shipping.
Old 02-08-2005, 11:45 AM   #9
nartkers
nartkers's Avatar
Are 71-72 different length than 70 centerlinks?
nartkers is offline   Reply With Quote
Old 02-08-2005, 03:23 PM   #10
Slammed67
Progress = 0%
Slammed67's Avatar
Keith,
I have an extra center link, but am not sure what year it is (67-72). If you can get me some measurements, I can see if it will work or not.
Jason
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 02-08-2005, 07:52 PM   #11
lolife99
lolife99's Avatar
Jason,... this is an old post,... and I will have to get back to you with the measurements. I'm not exactly sure what the difference is. I think it is the size of the inner tie rod holes. I ended up using the original one on my Blazer,... but I am in the market for any other ones. I don't think they are available new GM, or aftermarket. You might want to hang on to it if it's a '71-72. I will let you know. Thanks, Keith.
Keith
Convert to disc brakes.
Old 02-09-2005, 04:14 PM   #12
nartkers
nartkers's Avatar
My '70 centerlink measures 31.5" end to end, 23.75" center to center on the middle two holes
