It followed me home?
Horn problems/relay?
I cant seem to get my horn to work. The green wire going to the horns has power constant as well as the wire under the horn button on the steering wheel. I dont think that the wire should have constant power under the hood. I checked my chilton and it shows a horn relay in the wiring diagram, where is the relay? any other ideas?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I dont know for sure where it is on your mid 80's trucks but I think the horn feed runs straight back to the fuse junction so I will guess it is under the dash near the fuse panel . I think you actualy have 2 problems because you should "not " have a constant 12V at the feed wire but if you do and the horn will not sound then either the horn is bad or it is not grounding thru the base of the horn to chassis ground . Run a jumper wire from the battery + terminal to the horn and see if you get any action .
This might help you , the relay has 3 conections green to the horn , black to the switch and orange to the fuse panel .
Professional Grade
I took my relay apart becuase I was too poor to buy a new one, the problem with mine was that the switch inside had warped and wasn't making contact like it should, I bent it back, and its been good even since
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#5 | ||
Ha ha RUSSELL I was going to just pm you because I remember you had some problems with your and you tore it all apart, I figured you knew where all the wires and relays were. Where is the relay at? Quote:
thanks for the help guys
#6 | |
Stepsides RULE
Ha ha my horn is activated with a button on the turn signal. Almost everything inside the steering column is non functional except the steering shaft itself. here's a link to a pic of my horn button. http://www.cardomain.com/memberpage/563034/2
its a few images down, but you will see it quite plainly, along with my manual choke ![]()
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
