6768 vs 6972 Radiator support Identification
Never messed with anything but 71 -72 before but now working on a 1968 step.
I had a few rad supports in stock but never knew how to tell difference between the 2. I think this is an easy way to id. I have checked a few and it seems correct from what I have. Anyone else have different please correct me. 1967-1968 Chevy core suupport has turn signal hole up high 1969-1972 Chevy core support has turn signal wire hole down low
Chevy Freak
Core support
Solver, the 67/68 also has threaded holes for the splash pan along the lower front portion (6 I think). Also, if you look at where the headlights buckets mount, the 69-72 has a raised portion that is spot welded to the core support. There may be others..........
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
