Old 07-25-2004, 12:05 AM   #1
Mountain Man
Electrical light problem - tail lights/park lights/dash lights
Well, everything worked when I took the truck to the body shop, but wouldnt you know it, I now have some electrical light issues that I need some help with.
I have a painless wiring harness installed, and everything worke well, but since the truck came back from paint /body work I have the below issues:
1. Tail lights are not working. Headlights work, rear signal lights work, brake lights work, but no tail lights when headlight are turned on. Any Ideas? Do burned out bulbs in the side marker lights have anything to do with it?
2. Dash lights do not work any longer. With headlights on, no dash lights. Ideas?
All this stuff worked when I took the truck in for body paint work, and now I have these problems. The box was removed for work, but harness is pluged back in, and all tail section lights work minus the tail lights them selves, when headlights are on. Not sure why my dash lights no longer work also.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 07-25-2004, 12:11 AM   #2
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
aren't tails and dash lights on the dame fuse? does the dome light work? maybe a ground in the tails if they took them out??
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 07-25-2004, 12:19 AM   #3
Mountain Man
To answer question - No my dome light no longer works either. I don't think it is a fuse thing, I have the new blade style fuses with my painless system, and they all look good. They did remove the tail light housings. Do you think that the paint behind the housings is causing a grounding issue?
Full trim
Factory tach dash
A/C dash
Factory tilt
Old 07-25-2004, 01:21 AM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Check the various ground cables.Poss. the body shop disconnected them while doing the body work or painting.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 07-25-2004, 10:29 PM   #5
Mountain Man
TTT
Any other ideas.
Full trim
Factory tach dash
A/C dash
Factory tilt
