Old 07-25-2004, 11:26 PM   #1
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Question a new heater core = huge heat but it didnt fit well - why?
Hey all. I changed the heater core in my red 67 today & the core I got from the parts place was 1/4" thinner than factory. The instructions for the new one said that you may have to use foam &/or adjust the brackets & they also say that the 2" core is more efficient that the 2 1/4" old one. I used two pieces of blue house insulation foam to shim it up. It throws MEGA heat now. I've seen this post here before but I cant find it now via the search method. What did you all do to solve this problem? Could a guy get his old heater core recored OR are proper brackets availible for the 2" core?
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 07-25-2004, 11:36 PM   #2
Martin64
Martin64's Avatar
I made new brackets for mine. I'm not worried too much about OEM when it comes to a heater core as long as it fits in the box and I get heat out of it.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 07-26-2004, 12:50 AM   #3
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
When I had mine blow out, I tried two different cores from two different places. They were both exactly 1/2 inch too thin. I ended up having mine re-cored for about $80 at a local shop. It was worth it to me.
Oh, and now's a good time to put on a 12 or 13 pound radiator cap. You don't need a high pressure cap and the heater core will thank you.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 07-26-2004, 07:59 AM   #4
Blue Beard
Blue Beard's Avatar
When I changed mine the mounting brackets wouldn't even fit over the end caps. Had to go to a different brand, solved everything.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 07-26-2004, 08:17 AM   #5
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
I just snaged a pair o0f brackets from a later model truck. I believe the 69 up models used the thinner core.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
