Old 07-26-2004, 09:16 AM   #1
PLavelle
PLavelle's Avatar
Installing seat belts
I need to install seat belts in my 67 and I have a couple of questions.
1. Are these the right belts? I found them on one of the board vendor pages and I want to make sure that they're right.
67-72 Shoulder Harness Seat Belt
2. Can I install the seat belts myself or should I have someone else install them? I don't think this is something I want to screw up.
Thanks for the help,
Pete
PLavelle is offline   Reply With Quote
Old 07-26-2004, 09:19 AM   #2
PLavelle
PLavelle's Avatar
Here's a link to the page I found the belts on. They had some other selections but I wasn't sure which one was right.
Interior Parts
Old 07-26-2004, 02:50 PM   #3
PLavelle
PLavelle's Avatar
ttt
Old 07-26-2004, 08:03 PM   #4
walker
walker's Avatar
Hard to say if it the perfect fit or not. I'd just call the dealer and ask him. I bought some from So Cal speedshop. I had to have the buckle strap made shorter at an upholstry shop, (21" long as I recall). Also, I had to drill new holes in the floor to mount the reels. If I didn't have the gas tank behind the seat it would have turned out a little cleaner, but as it is it looks good, works good, and makes me fell a lot safer.
OOops, that is an old shot, it doesn't show the new belts, and the wife has the camera, so you will have to take my word for it that it looks good.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 07-26-2004, 08:24 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
That link is for Classic Heartbeat, Wes owns/operates it. He's a member here, hopefully he'll see this. ttt
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-26-2004, 11:03 PM   #6
walker
walker's Avatar
O.K. I went out and got a new pic, with the belts actually installed this time. Like I said, if the gas tank was not there, I would have mounted the reels back on the original belt mounting points and the other point where it is now. It is pretty close with the reels between the door and the seat.
Good luck.
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
Old 07-26-2004, 11:57 PM   #7
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Can you tighten bolts real good????..thats all you need to know.
don't worry to much about doing it.....it is really easy to do. if you have a 67 which I think did not have the provisions for lap belts even, then you will have to drill through your floor. Just use grade 8 bolts nuts lock washers (5/8 x 2inch size bolts will do the trick) and big washers to act as support for the hole in the floor. which ou can get at Autozone or oreillys or a hardware store you just need to put the holes in the right places for lap belts. if I get a chance when I'm installing my carpet I will remember to snap a pic and take some measurements of my 68 seat belt holes. As for the pillar holes for the shoulder harness type...I'm not sure how to go about that.
I got my lap belts at AZ, and did some fabbing to make them work a little better....if you have seen the ones from AZ, you will know what I'm talking about.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-27-2004, 03:14 AM   #8
jimfulco
There are some different types of reinforcing hardware here:
http://www.discountvantruck.com/truc...rseatbelts.htm
jimfulco is offline   Reply With Quote
Old 07-27-2004, 11:22 AM   #9
PLavelle
PLavelle's Avatar
I appreciate the help. I'll order the belts today and I'll probably be posting again if I get stuck.
