Old 07-26-2004, 01:27 PM   #1
n737nc
Quick question about TDC...
When the #1 cylinder is at TDC, where should the valves for that cylinder be positioned?
Should the intake valve be just closing?
Thanks,
Nick
n737nc is offline   Reply With Quote
Old 07-26-2004, 02:20 PM   #2
COBALT
COBALT's Avatar
It should be already closed I think, since the upstroke to TDC in the charge part of the cycle is compression of the fuel/air charge. It has to be in there to be compressed, so the fuel and air is homogenious for burning.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-26-2004, 02:24 PM   #3
n737nc
So basically, when the intake valve closes on the #1 cylinder the next TDC mark on the balancer will be the TRUE TDC?
Old 07-26-2004, 02:32 PM   #4
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Yep, assuming your marks are correct, it has to be. TDC is during the compression stroke. As such, both valves must be closed. Otherwise, you'll be exactly 180 degrees off (exhaust valve will be open).
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 07-26-2004, 02:39 PM   #5
n737nc
Alright, thanks!
I think I stabbed my dist 180 out. I am just looking for a way to check and make sure before I crank it over anymore.
Old 07-27-2004, 02:56 AM   #6
jimfulco
Might be easier to just switch plug wires at the cap. Swap each one with the one that's 180* across from it. If it starts, it was 180* out.
jimfulco is offline   Reply With Quote
