Old 07-26-2004, 05:41 PM   #1
68jimmy
68jimmy's Avatar
What years trailing arms will interchange?
I'm swapping the rear coil suspension from a 70 lwb 1/2ton into my 68 lwb leaf-sprung 3/4 ton. The trailing arms are badly rusted and I'd like to know what years are interchangable and if there is a difference in the arms between the swb and lwb...
thanks!
68jimmy is offline   Reply With Quote
Old 07-26-2004, 08:21 PM   #2
JHickson6
I Love This Stuff!
JHickson6's Avatar
All trailing arms are the same i believe, on the longer wheel base models the trailing arm crossmember is just further back.
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 07-26-2004, 11:25 PM   #3
68jimmy
68jimmy's Avatar
Do you know if the arms from a pre-67 will as well?
thanks..
Old 08-04-2004, 10:47 PM   #4
incoma
incoma's Avatar
I'd look on an online catalog to see if the pre 67 will interchange. I looked in my classic industries, year one and lmc books and didn't find the part numbers to compare.
incoma is offline   Reply With Quote
Old 08-05-2004, 06:51 PM   #5
68jimmy
68jimmy's Avatar
Actually I have found a set from a 66 3/4ton and they are the same except for the e-brake bracket found on the later versions... And the 3/4ton versions have the extra reinforcement plates to boot.
