hart
help 12 bolt swap problem
help on axil need to know if 10 bolt axils out of a 70's will fit in my 68 12 bolt posi
NOT REALLY BANNED!
![]() Join Date: Jul 2004
don't think so.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
hart
ok thanks id like to have a reason why
blood type; Retumbo
basically like putting a square peg in a round hole. length, diameter, spline count, bearing journal & manufacturer are all different.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
me3,
Are you wanting to swap axles or do you want to swap in the whole differential? Swaping the 10 bolt axles into the 12 bolt rear end wont work, but if you are looking at swapping the whole housing assembly in, you should be able to do it if both rear ends have the same spring arrangements. Jim |
hart
so basically what your saying is I should be able to take the posi guts and the spyder gears and pinion and stuff out and swap
No,
What I am saying is the whole housings assemblies can be swapped but none of the internals. Jim |
hart
sorry im a beginer what do you mean be housing assemblies
