Old 07-26-2004, 11:43 PM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Signs of a bad upper ball joint?????
I get an occasional "pop" on my drivers side when turning, in drive, while holding the brake pedal. usually occurs when I finish backing out of a parking space and put it in gear to go forward...
I have replaced the upper control arm bushings and shafts on both sides...but I have yet to do the lowers. I noticed that the drivers side ball joint was "squished" inwards, like when you squish a deflated ball. so I fattened it up a bit while lubing up the whole front end.....and it returned to that "squished" look again within a few weeks. could my ball joint be freezing up???? it does not seem to hold any grease.....and I do not know where it is going!!!LOL!!! could I have not tightened the ball jount to the knuckle enough...and it may just be moving in and out of the knuckle????
any help would be aprecciated....
also
after drving around quite a bit, the brake pedal gets a bit hard....I think it may just be air in my lines.....any other suggs????
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-28-2004, 09:57 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
carefully with a floor jack under lower arm remove upper arm from spindle. if ball joint stud moves around freely with little or no resistance it is bad. oh, by the way, after jacking up lower & before removing upper grab top & bottom of tire. if you can move it in & out it is bad also.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
