Saving 1 truck at a time!
Drip Rail Prep
I just stripped my drip rails down to bare metal this evening with a high speed grinder and small wire wheel. It is clean and shiny. What's the best prep to use under the seam sealer? Should it be sanded to give it some tooth and then use Prepsol? I wonder if I should use an epoxy primer or POR15 under the seam sealer in case it decides to crack and leak just like the OEM sealer? Any thoughts here?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
