Old 07-27-2004, 08:49 AM   #1
super-k
Want Facts on 2wd-4wd swapping
I`ve heard so many versions of cans and can`ts.Lets seperate Myths from facts.I`ve never tryed swapping,so I`m not claiming to know any facts.I`ve heard:frames are different in front,spring(leaf)perches are different in rear...Can you use a 2wd frame to install factory 4wd(same year)?What would it take to convert a K5 into a C5?Why are K20 cab mounts listed seperately?Who`s done what and what`s involved?
72CheyenneSuperK20CustomCamper350/TH350,A/C 72SierreGrandeK2500350/TH350,A/C 72CustomDeluxeK20CustomCamperSB400/4SPD.A/C 72CustomC10SWB,TH400,project
super-k is offline   Reply With Quote
Old 07-28-2004, 08:40 PM   #2
super-k
It`s still a mystery,I guess.
Old 07-28-2004, 09:11 PM   #3
Mudder
Mudder's Avatar
I just used a newer frame. Had the disks up front and was just a 1 and a half divverent than the short 2wd. Went pretty easy. Oh and the newer blazer tanks fit real well. My body man likes the thought of using a burb frame. He thinks it would work out better.
Mudder is offline   Reply With Quote
Old 08-03-2004, 10:37 AM   #4
super-k
Hey Mudder67,Thanks for the reply.Thought this would be a"hot"subject.Maybe questions need to be put up seperately.That`s a good tip.I see`73-`87 4wd shortys for sale alot and I wouldn`t care about the body.I have a diesel`91 burb(3/4t)w/4"EZride springs & 315/75x16 MTRs I either want to put a `67-`72 8`body or burb body on the frame.
Old 08-03-2004, 03:17 PM   #5
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
Sounds like you need my '70/72 4x4 SWB truck I'm selling
From what I know, If you are going from 2wd to 4wd, the easiest way to go is with a leaf-spring 2wd frame. The front Crossmembers will swap, but you still need to mount your shackels and such up front. I looked into doing this a while back but found it would be easier to do a bodyswap. However, plans changed once again, and I'm Step-Notching my SWB 2wd to lay frame this winter
Hope this helps some...
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
