Old 07-27-2004, 06:35 PM   #1
fordsux8269
torque specs
anyone know where i can get the frontend torque specs on the net ie.. control arms and shocks stuff like that
1982 chevy swb fleetside
fordsux8269 is offline   Reply With Quote
Old 07-27-2004, 07:02 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Lower control arm shaft U-bolt = 85 ft.lbs.
Upper control arm shaft nuts = 70 ft.lbs.
Control arm rubber bushings = 115 ft.lbs.
Upper ball joint nut = 50 ft.lbs. (plus additional torque to align cotter pin. Not to exceed 90 ft.lbs.)
Lower ball joint nut = 90 ft.lbs. (plus additional torque to align cotter pin. Not to exceed 130 ft.lbs.)
Stabilizer bar to control arm = 25 ft.lbs.
Shock absorber upper end = 140 ft.lbs.
Shock absorber lower end = 60 ft.lbs.
This came from my 85 manual and is for a C-10.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
