Old 07-28-2004, 03:01 AM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
rear view mirror help
does a rear view mirror for a 69 bolt or stick on
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 07-28-2004, 08:15 PM   #2
jamie72
jamie72's Avatar
it bolts on...71-72 stick on.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 07-28-2004, 08:17 PM   #3
71swb4x4
71swb4x4's Avatar
To add to Jamie's most 71's will bolt and all 72's will stick.
I have a 71 with original bolt on mirror, and nearly all 71's I have seen have the bolt on.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-28-2004, 08:39 PM   #4
Ironhorse
Ironhorse's Avatar
Have to agree with the bolt-on for '71 cabs. My '71 4x4 has a "raised" mounting pad stamped into the inside cab roof line. I have a couple of the "glue-on" windshield style, not sure if they are the correct mirror for a '72 application. The 67-70 style mounted to a arm mounted to a flat roof line if I am correct. Some one else may have more info.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
