Old 07-28-2004, 07:41 PM   #1
TIMSPEED
TIMSPEED's Avatar
Is this a fair price for a Posi install?
I called around today about getting an Eaton Posi put in my truck. I can get an Eaton Posi for $350 from West Coast Differentials. Then get an install kit for $100 from Summit. A local shop quoted me $300 to do the job, and they could have it done in a day. Does that sound fair?
On a Side Note...The Detroit TrueTrac that I ORIGINALLY wanted ISN'T made for a Series-3 carrier (damnit!).
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 07-28-2004, 07:44 PM   #2
cochino12
It followed me home?
cochino12's Avatar
I'm not 100% sure but sounds really high to me. I paid a mechanic to do mine for like $100, then again he works out of his house so go figure?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-28-2004, 07:45 PM   #3
TIMSPEED
TIMSPEED's Avatar
Hmm..It was the first place I called actually...I was expecting like $1000 to install..when I heard $300 I was like YEAH!! I may call around some more.
See Them Here
Old 07-28-2004, 07:50 PM   #4
bigblock73
yeller
bigblock73's Avatar
I paid $350 to have mine installed, and that was 7 years ago. So, I don't think that price is too far out of line.
bigblock73 is offline   Reply With Quote
Old 07-28-2004, 07:52 PM   #5
cochino12
cochino12's Avatar
I stand corrected. Guess I got a pretty good deal!!
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-28-2004, 07:59 PM   #6
TIMSPEED
TIMSPEED's Avatar
Is it easy to get sideways with the Eaton? I mean, I'm buying it to GET traction..but with Radials on, I'd like to be able to get sideways easily
See Them Here
Old 07-28-2004, 08:17 PM   #7
low 84
low 84's Avatar
the shop that is setting up my ring and pinion and putting my locker in is doing it for 175
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 07-28-2004, 08:18 PM   #8
TIMSPEED
TIMSPEED's Avatar
Hmm..I'll call around. This place is just a place that was recommened to me.
See Them Here
Old 07-28-2004, 08:26 PM   #9
cochino12
cochino12's Avatar
Mine goes sideways realy easy, its almost too much fun.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-28-2004, 08:29 PM   #10
TIMSPEED
TIMSPEED's Avatar
goooood. Should be getting them dropped in by my birthday.
See Them Here
Old 07-28-2004, 08:29 PM   #11
swervin ervin
You get what you pay for
swervin ervin's Avatar
When I had my Auburn Gear differential and Richmond 3.73's installed, it was $160.00. This was a pro mechanic working out of his engine building shop. Are you having gears installed at the same time?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 07-28-2004, 08:31 PM   #12
TIMSPEED
TIMSPEED's Avatar
No, just posi unit. Reusing stock housing, carrier, ring & pinion. I'll call around before I do the job..maybe I can get it done for $200...The quote was $275.
See Them Here
Old 07-28-2004, 08:51 PM   #13
swervin ervin
Well, the $160.00 was with me carrying the rearend to him, out of the truck. Everything was cleaned up and ready to go. He installed everything and even bought new axle bearings that I forgot to get. I imagine if it's still in the truck it would be higher. Not much to installing the posi unit. Setting up the gears is what takes time.
Old 07-28-2004, 10:03 PM   #14
bigblock73
yeller
bigblock73's Avatar
I should clarify I guess, mine was $350, but I forgot to mention I changed gears too. I brought them two twleve bolts, mine (unknown gear and non posi) and the other 12 bolt (from a 67-72 I believe, and it had the 4.10 and posi). I installed the diff assembly when they were finished.
Old 07-28-2004, 10:13 PM   #15
bluex
bluex's Avatar
I put a zexel-torsion in my S10 myself. If you just installing the posi, its a R&R deal. Get new bearings put on it before you start. Its easy, just put the shims and bearing caps back on the same side. I did this when it had about 10k on it, I now have 96k and no problems out of the rear. I had never even seen the inside of one before that. I've helped do a few more, and a couple of the guys bought the install kits to make the gears mesh better, but we always ended up reusing the stock shims, they made the best pattern.
The detroit true-trac is the one with gears and all like the zexel right? I was wanting one of those for the '78. Are my 3.08's a series 3?
bluex is offline   Reply With Quote
Old 07-28-2004, 10:17 PM   #16
1FaastC10
1FaastC10's Avatar
two words... LOCK RIGHT. just a lunchbox locker, which replaces your spider and side gears and you dont have to disturb anything else.
1FaastC10 is offline   Reply With Quote
Old 07-29-2004, 11:18 AM   #17
Grim Reaper
Doing a posie without changing gears is not hard on a corp axle. You not having to touch the pinion depth and that's where it becomes a pain.
Go buy a dial gage from Northern or Harbor freight. Check the run out on the carrier. Check and wrte down the gear lash. Get you new posie and new bearings and have the bearing pressed on. Play with the shims till you get the same lash. Make sure it goes in TIGHT with the shims. Tapping it in with a rubber mallet is not a problem. New bearings need a little preload. Your done.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 07-29-2004, 12:43 PM   #18
BaggedC10
Under construction!
BaggedC10's Avatar
I can't give you a price, since I had a complete posi. rear-end built.
Yes, you will be able to get sideways easily w/ an Eaton!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
