07-29-2004, 11:08 AM | #1 |
Lovin' Arizona Since 1961
Tire Size??
I have a '70 short bed and scored a set of 15 X 8" ralley wheels for it. These are kinda wide, but what is a recommended size tire for these? Thanks for helping the new guy. H.
07-29-2004, 01:23 PM | #2 |
Fabricate till you "puke"
A 275/60/15 will fit the wheel nicely, or if you like a little taller....I run a 255/70/15 on the rear of my longhorn. Up front you my opt for a slightly smaller tire (275/60 rear- 255/60 front). best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-29-2004, 10:06 PM | #3 |
Can you run a 275/60 in the front? I am wanting to get all 4 the same size so I can rotate and have a spare to fit. Thanks
1971 LWB Chevy C-10 350/350 3:42 eaton |
07-30-2004, 08:16 AM | #4 | |
Watch out for your cornhole !
07-30-2004, 12:47 PM | #5 |
The Blazer King
I run 345-50-15 on the rear and 255-60-15 on the front. Fit nicely.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
