07-29-2004, 04:33 PM | #1 |
Just here to help
Question about serpentine system.
I have a chance to get a setup off of a 89 burb and was wanting to know if it will bolt up to a 350(crate that came from Pace),and if there is something that i would have to do to make it work?Anyone done this?Any pics of the setup?Thanx guys.
07-29-2004, 05:24 PM | #2 |
Get a water pump for the serpentine system instead of v-belt. If ya don't, the water pump will turn backwards and not cool. Ran across this with V6 chevies in forklifts. Drives ya nuts till ya figure it out.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
07-29-2004, 05:58 PM | #3 |
Just here to help
Will it all bolt up ok besides the water pump?
07-29-2004, 06:45 PM | #4 |
To be honest, I've never tried it. I would think that if the mounts/holes in the head were right, it should. Don't take my word on this. Some of these other guys on this board have done it. Ya might wanna check FAQ at the beginning of the board? Or keep updating your post and maybe someone who's done it could post and help ya out more?
07-29-2004, 07:13 PM | #5 |
Got a serp belt setup off a 92 1500, bolted it right in place on a 76 400. If you have holes in the front of the heads it will work. Swap power steering fitting at back of pump. Reverse water pump as mentioned. Also need a reverse fan if you're using a belt driven fan. Brian
07-29-2004, 11:20 PM | #6 |
Take everything off the burb including accessories, braces and pulleys. You will have to probably drill and tap one hole in pass side head. Find a fan shroud off a big block.
Thats about it unless someone sees something I missed.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
