radiator hoses for a LT1
I have installed a LT1 in a 1972 4x4. I would like to know how others with a LT1 have hooked up the radiator hoses since you have different size outlets on the water pump and stock radiator.
Mike |
Personally I suggest geting an aluminum radiator to help cool it down a little. You can pick up a used camaro radiator pretty cheap if you look around. if you really want to use the radiator you have you can take the smaller of the two inlets, put the hose that fits on it over the inlet, cutthe hose flush with the inlet, then slide the bigger hose over the top of that hose. You might have to put some KY Jelly on it (Don't laugh, I keep some liquid KY in the toolbox, it works great and doesn't hurt anything). be ure and clamp it down tight and it will work just fine. That's how mine is setup on my engine, with a newer radiator.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
![]() Join Date: Jan 2001
For the bottom hose I went to a place that makes hoses. I bought an adapter that is 1 1/4" on one end and 1 3/4" on the other. Then I connected the hoses to the water inlet and the bottom of the radiator. You will have to shorten the two hoses to put the adapter in there. By the way I also put a T for the fitting/hoses to the back of the heads. I believe it is called a steam pipe. To elaborate, the T goes between the adapter and the water inlet on the front of the engine. Hope that makes sense. Kerry
1967 C10 1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT 2018 Durango RT |
Thanks for the responses. I have a brand new four core radiator so I don't think I will have cooling problems. Wootdog Did you put the tee for the steam vent in the lower or upper hose? Does it really matter where it dumps? On my Corvette it dumps in the radiator. I was planning to dump it in the top hose. What did you do with the upper hose to make it fit? Did you use the 1 1/4 hose and heat and stretch it over the top 1 1/2 radiator fitting? What hoses did you use to connect? did you just go to the parts store and pick and chose what looked right or did you ask for something specific? I tried some flex radiator hoses that had the two different sizes but they didn't work well at all.
Mike |
Just a thought: Is it possible to weld on an exhaust type reducer? That's what I used when I did my rear gas tank conversion since the filler necks were different sizes.
Re: radiator hoses for a LT1
I just finished putting a Champion 3 row radiator in my 68 C10 with LT1 engine. The radiator hoses were a bit of a challenge but I finally got it figured out. The bottom hose is a Gates 21055 which 1.75 on the radiator side and 1.5” on the thermostat housing. It fit perfect with no trimming. The top hose is Gates #20607, which is 1.5” on both ends. The top hose required substantial shortening on both ends to fit right and I installed a sleeve in the middle with a 3/8 hose barb for the steam line.. Both these hoses need to be installed with a 1.25 to 1.5 sleeve adaptor on the water pump end. The Gates number on the adaptors is #263900.
Got pics? You sticking with the Opti-Spark or using some other type of ignition? What tranny? I lived with an LT1 for over two decades so I'm curious. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Moderator
![]() Join Date: Dec 2012
Assuming we're talking 92-96 LT1, you need to remember that it is reverse cooled.
Bookmarked in case I get the itch to use one of my spares, thank you.
Jack 1968 swb on air |
#10 | |
Tranny is 700R4 with TV cable control. Pictures attached. |
#11 | |
Look at that...nice. It's a stout motor! -klb
![]() Join Date: Jan 2003
Nice
1969 307, t3501950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
#13 | |
Andy
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 LT1|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
#14 |
Which LT1 version are you using? I believe the power steering pump locations differ between Corvette, F & B bodies.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
| Bookmarks |
