Old 07-29-2004, 07:20 PM   #1
76bonanza
76bonanza's Avatar
Temp sender
Is the temp sender in the block filled with oil? I thougt I saw a little drop of oil oozz out of it two days ago. The is from the sender not the block right? It seems to function still. Should I be concerned? Or will it just stop working if it all leaks out? Just want to be sure it is reading correct still.
How much coolant will I have to drain to pull it? And were can I get new one just napa or something?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-29-2004, 07:54 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
No, not any oil in it that I know of. You are talking about the one in the drivers head, right?
If you have to replace it, just drain the coolant low enough to where the level in the radiator is below the sender.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 07-29-2004, 08:01 PM   #3
76bonanza
76bonanza's Avatar
Yes I was tightening it so the nut part would be flat by header flange and between the outer rim and inner core it looked like some black oil leaked out not much. It seems to work think it will be ok? It would work or not work right? Or can it give incorrect readings? I thought maybe the were filled with oil or something? I think I will just watch it and go from there. It is not dripping off or anything in fact i can not see it anymore.
1968 c10
lowered 3" 4"
Old 07-29-2004, 09:10 PM   #4
Paradise Ridge
Paradise Ridge's Avatar
76bonanza,
Funny, I just called NAPA today about temp sending units.
3 months ago I picked one up for my '82 K30 (454) and it hasn't been registering on the gauge. I posted a question here on the board and the opinion was that they gave me the wrong unit.
Napa has the unit for "Idiot Lights" for $14.95, and the one for gauges is $6.95.
Make sure you get the right one, I'm picking up the "gauge" one for my truck tomorrow. Anybody need a nice brass paperweight?
My nickels worth,
Scott
Paradise Ridge is offline   Reply With Quote
Old 07-29-2004, 09:26 PM   #5
swervin ervin
Maybe when you were tightening it, some sealer or gunk ozzed out from around the threads or something. Far as I know you are right. They either work or don't. I don't think I would worry too much about it unless it quits working or coolant start leaking out.
Old 07-29-2004, 10:05 PM   #6
76sierraclassic
When I bought my '76 back in November, the temp gauge didn't work at all. I suspected the sending unit, so I bought a new one at O'Reilly Auto Parts. I replaced it, and then when the engine started warming up, the gauge would peg completely out. It kinda freaked me out at first, but my dad used one of his temp guns and we knew that the engine wasn't getting too hot. I wound up having to get a second one from O'Reilly (free of charge of course), and now it seems to work like a charm.
Mike
76sierraclassic is offline   Reply With Quote
Old 07-30-2004, 11:16 AM   #7
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Sounds to me like you need to change your blinker fluid. Must be some restriction in the blinker lines and the fluid is backing up into your temp sender....
NeCrOmAnCeR is offline   Reply With Quote
Old 07-30-2004, 11:24 AM   #8
76bonanza
76bonanza's Avatar
I started reading that and was like blinker fluid?
1968 c10
lowered 3" 4"
