07-30-2004, 02:57 AM | #1 |
78 Crew Cab Doord Won't Latch
I'm not sure what the problem is with my passenger and driver's side front doors, but I have to slam them shut to get them to latch al the way. How do I fix them so they latch all the way with only lightly shutting the door? I'm afraid this will start busting things off inside the doors! Help! |
07-30-2004, 03:14 AM | #2 |
Professional Grade
You probally need to adjust the striker (the bar that sticks out of the door, I think?)
Never needed to bother with it, but I do know that you have to loosen something, move it to where it should be, then your door will close. Sorry I'm not much more help here!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
07-30-2004, 07:53 AM | #3 |
yeller
It could also be from the doors sagging and not hitting the striker bolt correctly, if that is the case, you will need to rebuild/replace your door hinges.
Oh, and welcome to the board.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
07-30-2004, 08:50 AM | #4 | |
Happy to be here
Try getting the door almost closed and lifting up on the door handle. If you have up and down play the bushing are worn. You can buy kits to repair them at some auto parts. Welcome to the forum....
07-30-2004, 10:54 AM | #5 |
The plastic peice on the striker bolt is missing. It makes the diameter smaller and as such it doesn't trip the latch. If you adjust the striker so that it latches then the door will probably rattle.
Help section at pep girls or Auto zone. They sell a new striker but right buy it they will sell some gray bushings listed for a Ford. There will be 4 in the package and cost less then the GM striker. They will work but a VERY tight fit when you pound them on.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
07-30-2004, 10:58 AM | #6 |
http://ken-co.com/hingepin/door.htm
It shows a drawing of the part in top right. The GM striker is like the Ford Strikers farther down with the gray sleave.
07-30-2004, 12:01 PM | #7 |
North Coast, baby!
I've been working on the same problem. I replaced the striker bolts first and it kept the doors tight and they closed easier. Check the body lines on the doors too. Are they in line with the front fender and bed? My driver's door wasn't. The hinges were good but the bushings were shot. It's a process of elimination. If you put on new striker bolts don't torque them down right away. Snug them up a tad and shut your door to set it in the right spot. The striker should not be supporting the door, just keeping it closed. After that you can torque them. Just be sure they don't move when you tighten them or you'll have to start all over. Good luck.
79 Chevy Scottsdale (BigBird) |
