Old 07-30-2004, 11:06 AM   #1
charlieo
Parts out of a 74 blazer
OK guys I need your advice. A friend of mine called yesterday and said he knew a guy thats selling parts off a 74 blazer . He said eng/trans/transfer/front diff for $200.00. I know I can't beat that deal since eng runs & I need a front diff for my 69 4x4 project . Is there anything else I should grab ? I don't think the gas tank will work will it & should I get the filler neck ? Which front hubs are the better ones to have for cross-over steering ? Thanx alot for the help !!
charlieo is offline   Reply With Quote
Old 07-30-2004, 12:35 PM   #2
JimKshortstep4x4
Smile
How about the console and buckets?
Jim
Old 07-31-2004, 09:24 AM   #3
charlieo
Buckets
Would the buckets be the same as the buckets in a 70-72 truck ? I was looking @ them yesterday & their pretty rough but maybe worth having.
Old 07-31-2004, 06:53 PM   #4
Rod
The buckets can be re-skinned with correct seat covers to make them look correct. If they are the low back type.... I can't remember for sure but I think in 74 you could get high back buckets as an option perhaps. The 74 seat brackets however are 1.5 inches higher than the 69-72 type. So the seat will sit that much higher overall.
Console could be either variety in that year,... could have seat belt holders or cup holders... still worth a few bucks regardless there too.
But it sounds to good a deal to pass on... I'd buy it.... heck I could always use a spare transfer case and diff if your short $.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-31-2004, 11:35 PM   #5
charlieo
74 4x4
Thanx for the advice ! Me & a buddy bought it for $200.00 . He's taking the 350 & trans (TH 350) for $100. I'm getting the Rochester carb, front & rear axles (4:11 , good for some 35" tires I think). I'm also getting the front sway bar, transfer case ( it looks like a np203) plus I'm going to take the buckets and the brake booster w/ the mstr cyl. I couldn't see the proportioning valve though . Did some of them come without that ? I'm going to put the D-44 w/ the disc brakes on my 69 will it work with this mstr cyl & no pro valve ? My take is going to cost me $100.00 . I'm stoked
