Old 07-30-2004, 11:39 AM   #1
71GMCStepside
Gettin' there
71GMCStepside's Avatar
Question Motor Mount Bolts
Somehow, I have managed to lose my motor mount bolts. I finally bought a set of new motor mounts for my 71 yesterday, but I have no idea what size bolts I need to mount them to the block.
Can anyone help me out here please?
I have a SBC 350.
Thanks!
[/B]71 Chevy Short Step - Ground Up Restoration In The Works, If I Live That Long...
71GMCStepside is offline   Reply With Quote
Old 07-30-2004, 11:56 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
to the block-- 3/8 x 3/4 long
Old 07-30-2004, 11:59 AM   #3
71GMCStepside
Gettin' there
Thanks Tx Firefighter! Any idea as to what type of threads??
Old 07-30-2004, 12:00 PM   #4
Tx Firefighter
It's the course threads, I believe it's called a 3/8-16 bolt, get em 3/4 long. Or, 1 inch long and a good thick washer if you want to.
Old 07-30-2004, 12:01 PM   #5
71GMCStepside
Gettin' there
Sounds great. Thanks again
Old 07-30-2004, 12:03 PM   #6
71GMCStepside
Gettin' there
Since you're such a wealth of great information, any idea about what bolts I need to connect the motor mounts to the towers??
I'm full of questions, aren't I?
Old 07-30-2004, 03:53 PM   #7
buckola
1 Wrench / 10 Knuckles
buckola's Avatar
If I'm not mistaken the motor mount bolts are a 7/16-14 thread . Thats the ones that are a biotch to get at.
1970 GMC Custom
Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers
2006 Dodge Charger SRT8. 1/4 mile 13.3
1973 Z1 900 Kawasaki ( all original)
buckola is offline   Reply With Quote
Old 07-30-2004, 04:31 PM   #8
Tx Firefighter
Nah man, he asked for the ones that screw into the block, those are 3/8 for sure.
The one under the mount that goes through the frame stand is the one you're thinking about, it's the bigger 7/16 one.
Old 07-30-2004, 07:00 PM   #9
crazy longhorn
Fabricate till you "puke"
Yes, as already posted , the tower to mount bolts are 7/16 X 14 NC thread. 1 - 1 1/4 " long should work there, & they have a lock, & a big thick flat washer . if you still have the eng out of the truck, you will do yourself a big favor by drilling the holes in the eng stands out to 5/8" best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-30-2004, 07:34 PM   #10
71GMCStepside
Gettin' there
Thanks everybody! I really appreciate the info
