Old 07-30-2004, 02:54 PM   #1
Hunter
Lovin' Arizona Since 1961
Hunter's Avatar
Ralley Wheels: What Would YOU do?
Hey Y'all, I'm new here so bear with me. I have a '70 C10 shortbed that has the original body and paint, but I added disc brakes, power steering, posi rear, 350/350 etc. I put standard (7"?) ralley wheels on it years ago when I bought it for $1500. My wife calls it our farm truck, I'm leaning more toward street... Anyway, I came across a set of 8" wide ralley wheels in good shape. Would you run wides on the rear and narrows on the front for that classic look? I have a good friend who would take the extra set for his GMC, but then I have 2 different sets of wheels... Also, thanks for the tire size input on another forum, but I'm still listening to advice regarding tire size. Everybody like Radial T/A's? THANKS and man do I love looking at 67-72 Chevy pickups! Hunter
Hunter is offline   Reply With Quote
Old 07-30-2004, 03:04 PM   #2
'70_402
'70_402's Avatar
go with same all around!!! no question..
'70_402 is offline   Reply With Quote
Old 07-30-2004, 03:06 PM   #3
68 Suburban
68 Suburban's Avatar
I have 8 inch Corvette style Rallies all the way around on the burb. I prefer black wall out, but I can understand if someone wants white letters out
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 07-30-2004, 03:07 PM   #4
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Hunter,
Welcome Aboard!
Glad to see someone who's willing to keep with a factory look regarding rims. IMO the 8 inchers give much better tire options for anyone running larger than say a 235/75R15 tire. I'm running a set on my '92 with 10.50 mud grips (rear), and they fit great. You can run 8's all around and get the big/little look with the tires.
I ran T/A's on my Camaros and found them to be really good wearing, and easy to balance. With the 8 inchers, you can easily do 265 or 275 and not bulge the sidewalls.
Where you might have trouble is with the backspacing on your '70, particularly with wide tires on the front. They don't set out as far as aftermarket rims.
Keep it shiny side up...SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 07-30-2004, 03:30 PM   #5
Putter
More Cowbell....
Putter's Avatar
Welcome from Cental Mississippi. I run 8" ralleys all around and love them.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 07-30-2004, 03:42 PM   #6
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I have 345-50-15 on 8 inch rally's on the rear (STUFFED). 255-60-15 on 7 inchers on the front. This is by far the best looking combo I have seen. They are approx the same height tires. The front's are not too skinny either.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 07-30-2004, 04:19 PM   #7
fast71
Drive it like U stole it
fast71's Avatar
welcome from north GA , here is my truck with 8 inc ralleys and 255/70/15 BFG's
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 07-30-2004, 06:35 PM   #8
crazy longhorn
Fabricate till you "puke"
I run 15x 6 1/2"(van) ralleys up front , with a 225/75 tire. at the rear are a set of 15 x8's, with 255/70 rubber.....15 x 10's are on the bench till i can afford the tires. IMO, these trucks handle better with a little less width on rubber up front, & I like the "bigs & littles".....1 " to 1 1/2" taller at the rear. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-30-2004, 06:57 PM   #9
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
I'm running 275x60x15 in the rear, and 215x60x15 in the front, both are radial T/A's. Truck has a mean looking stance now...
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 07-30-2004, 07:17 PM   #10
67cst
i love summertime
67cst's Avatar
ive got 275 60s on all 4 corners on 8 inch ralleys, no rubbing upfront at all, i think some guys on here have 295s on the front
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 07-30-2004, 07:28 PM   #11
miket
miket's Avatar
15X8's in the front---15X10's in the rear---275/60's all the way around.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 07-30-2004, 08:15 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I run 8 inch Rallys all around with 245/60s up front and 275/60 in the back.
It's lowered a bunch and still doesn't rub anything.
I've run 275/60s on all 4 corners on 8 inch rally wheels before under non-lowered trucks. They didn't rub either.
Old 07-30-2004, 08:43 PM   #13
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
i like to run wider in rear 10sand 8s 0r 8s and 7s
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 07-31-2004, 01:52 AM   #14
SCOTI
SCOTI's Avatar
15x6.5's up front w/215-70's & 15x8's out back w/255-70's (I had 275-60's).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-31-2004, 07:11 AM   #15
dennis111
dennis111's Avatar
I've always been partial toward the "retro" look of wide tires in the rear.
Dennis
68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . .
dennis111 is offline   Reply With Quote
Old 07-31-2004, 12:42 PM   #16
ChevyDude
Chrome Ralleys, 15x7 in the front and 15x8 in the rear....soon to be dropped!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 07-31-2004, 12:45 PM   #17
ChevyDude
One more:
Alex
Old 07-31-2004, 12:58 PM   #18
miket
miket's Avatar
Originally Posted by ChevyDude
One more:
Nice shop----nice truck.....wish mine was getting that treatment.
Old 07-31-2004, 01:05 PM   #19
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
I have 15x8's with 31x11.5's all around. no rubbing either....they are a bit over sized from stock, but they take up fender well space well....
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-31-2004, 09:58 PM   #20
Harold Shepard
I used the 8" rallys and 275/60s and then used the stock full wheel covers on top of them, wide wheel and tire= full wheel well and cap = stock look.
Harold Shepard is offline   Reply With Quote
