Old 07-30-2004, 06:58 PM   #1
bgood
bgood's Avatar
Need alternator bracket
For my 67 C10 with 350 engine long neck water pump...wanting to move alt to driver's side since I now have a a\c pump on the passenger's side. My 'net searches have turned up a lot of brackets for passenger side but zilch on driver's side... Am I looking for a Unicorn here? any help appreciated!
1967 C10 Short,Step
283\1460 Holley HEI Ign.
Borg Warner T56 6 Speed!
A-1 Electric life pwr windows
PS,PB,Tilt
275\60R'S on Alum Mags all around
Vintage Air A\C
Grey cloth Buckets
bgood is offline   Reply With Quote
Old 07-30-2004, 07:40 PM   #2
MOTHERTRUCKERS
If your not running power steering use your 67 alt brackets spaced out from the block with 3/8's id sections of pipe cut to the right length, if you have p/steering use 69-72 brackets and pipe. Most hardware stores have short black and galvanized sections that are threaded but you cut the threads off at each end to the length you need and paint them. I have both 67-8 and 69-72 brackets if you need them
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 07-30-2004, 07:53 PM   #3
bgood
bgood's Avatar
Thumbs up Thanks
Thanks MT, I'll give my local guys another shot on this one if they can't turn one up I'll get you to send me one. Thanks again, Bill
1967 C10 Short,Step
PS,PB,Tilt
Vintage Air A\C
Grey cloth Buckets
Old 08-01-2004, 03:12 PM   #4
GMC AMI
GMC AMI's Avatar
68 drivers side alt. brackets.
Bill, I have an original set on a 50 k mile 68 327 for 20 + shipping if needed,Mike
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 08-02-2004, 08:41 PM   #5
bgood
bgood's Avatar
Arrow MT, Mike, thanks
You have pms and or email regarding brackets.
Thanks for your help, Bill
1967 C10 Short,Step
PS,PB,Tilt
Vintage Air A\C
Grey cloth Buckets
Old 08-03-2004, 05:08 AM   #6
GMC AMI
GMC AMI's Avatar
Header brackets.
PICS of alt. brackets for headers.
Old 08-03-2004, 05:31 PM   #7
GMC AMI
GMC AMI's Avatar
Smile 1972 driver's side alt. mounts.
Bill, here is what I found that bolt to the heads on the driver's side above the ps pump. I hope this helps, Mike
Old 08-03-2004, 05:38 PM   #8
gr8scott51
gr8scott51's Avatar
Try www.alangrovecomponents.com I got what I really wanted in the form of brackets there.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
