shaved tailgate question
does a person have to weld to shave a tailgate? will body shops shave a tailgate - and whats a decent price? also my tailgate is messed up (as they all are) you have to pull up and out you know to get it to open what is the best way to rectify this? thanks
BAD BOW-Silverado XST
Why shave it? Cover it.
hwere do you get the cover at? and where do you get a good handle relocation kit?
Parts and more parts
Try Sir Michaels, Mar-K, or even LMC they all have items for tailgates.
I went with a Sir micheals relocator and filler. Then I used body panel adhesive instead of welding to avoid warping...worked out great
Daily Driver: 1992 Blazer dropped on rallys ![]() Project: 87 GMC shortwide, About to get a little boost ![]() |
I bought the louvered skin from www.mar-k.com. The tailgate relocator too. It's one of the best I found. Cost about $75. The skin is tack welded and glued to the tailgate. The tailgate is considerably heavier.
Stepsides RULE
put my vote in Sir Mikes, im getting that smooth bolt on roll pan for the stepside and the tailgate cover.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
thanks for the help!
oh yah - i hafta lift up on my tailgate to get it to open and i have to hold the handle open to close it.. whada i do to rectify this? also where do i get body panel adhesive?
I duuno.. the idea of spending a load of cash for some bent metal, not even compound bent, kinda irks me. I'll get a handle relo kit, but will probably skin it myself. I know, it'll take longer, i may even have to redo it, but not so much the money, but doing it yourself does have a bit of satisfaction. Think abotu it.. what you're reallt covering is the center section, and the handle pull area. nothing says you can't at least try. i have a silverado with the cover plate, so I can use that as a bit of a guide. not too bad. I'll let you know how it goes, i wanna get it done by the end of the year. I'm going to use 18ga, that's good enough since it's just a cover, otherwise I'd use 16ga, but that's a bear. I don't slam it anyway. even if I have to use body filler, it will be minimal.. No Bondo! lotsa other good stuff, more expensive, but better, lighter, etc.
#11 | |
![]() Quote:
Another vote here for the Sir Michael's handle relocator kit. I bought one and cut up a brand new tailgate to put it in - without ever doing it before
Kent Ballan ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP! ![]() ![]() ![]() |
#13 |
BeWarE tHe eViL CrAnkTOe!
Yeah.....What they said!! hehehee
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
