Old 07-31-2004, 12:00 AM   #1
bbchevy
87 Wanna Be K30
bbchevy's Avatar
Unhappy Need Help Please...i Have No Brakes...ahhhh!!!!
a few days ago i decided to bleed my brakes on my 93 1500. as i started to bleed the rear brakes, no fluid would really come out. my girlfriend said that the pedal wouldnt go down either. i was reading my chiltons repair manual and it said something about needing to hald down a pin or something in the combination valve? well anyway, so brakes worked fine before i started and by the time i was done, i hadn't any rear brakes??!?! none whatsoever. plus on top of that, the pedal hangs out down by the floor now. i can stop, but, yea i dont think i like it this way. scares the **** out of me. now if its the combination valve or whatever, can i just say screw all the random valves and computers and just convert it to a single prop valve and nothing else. ya know, like the older trucks. the normal trucks. aaaahhhh soooo confused! im getting the point where i wanna sell it.... wait no i dont... PLEASE HELP ME!!!!!!!!!!!!
bbchevy is offline   Reply With Quote
Old 07-31-2004, 06:33 PM   #2
99-2door
99-2door's Avatar
There is nothing special you have to do for the rear brakes. Are you sure you were bleeding it properly? Had to ask.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 07-31-2004, 07:33 PM   #3
Z16
If you are bleeding brakes on ANY vehicle with anti-lock brakes, it must be pressure bled. There are many small passages in the ABS module that do not bleed with the normal method. This is extremely important. We experimented on my 98 when I changed the master cylinder, and before we pressure bled the brakes sucked. Also remember, that on a lot of ABS vehicles, the pedal will always feel a little spongey. Gotta love all that new technology
Z16 is offline   Reply With Quote
Old 07-31-2004, 07:34 PM   #4
bbchevy
87 Wanna Be K30
bbchevy's Avatar
im sure i was bleeding them right because i've done it before on other trucks just like it. and my dad was helping me too... so yea im lost
Old 08-01-2004, 09:19 AM   #5
Z16
You can probably find a pressure bleeding system at an auto parts store. I think there are some affordable ones out there. They basically force the fluid thru the system, and that gets the air out of all the small passages in the ABS module.
Old 08-01-2004, 12:03 PM   #6
bbchevy
87 Wanna Be K30
bbchevy's Avatar
cool, thanks alot.... i was actually just looking up pressure bleeders after i read your first reply... so ok ill try that and see what happens. thanks again.
-Scott
