Old 07-31-2004, 08:34 AM   #1
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Dome light
I Was looking around my truck (Still finding new stuff), and foundout that it used to have a dome light. My question is, did they come stock on 69 pickups?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 07-31-2004, 08:50 AM   #2
71swb4x4
71swb4x4's Avatar
Dome lights were stock. You are talking about the one inside the cab above the rear window?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-31-2004, 08:56 AM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
yup, so they came stock on all trucks or was it an option?
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 07-31-2004, 08:58 AM   #4
71swb4x4
71swb4x4's Avatar
They are stock. Should come on when you turn the headlight switch all the way counter-clockwise if I remember right.
A popular mod is to install the door switches and wire it up so it turns on with the door opening like newer cars.
Old 08-01-2004, 05:50 PM   #5
1972C10
1972C10's Avatar
Alot of Trucks Came with that option After 68 there was a pad on the front of the cab between the door hinges you can drill tap and install a door light switch off any 69-87 3/8 16 is what thread it is drill a 5/16 hole tap it out fish a wire into that hole to under the dash hook it to the dome light ground wire. When tightening The switch push down on the plunger so the wire doesnt get twisted up.
1972C10 is offline   Reply With Quote
Old 08-01-2004, 06:08 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Mine has the dome light door switch option on the glovebox sticker. At first neither switch worked, so I sprayed some WD40 in 'em and worked 'em back and forth with my thumb and they started working.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
