Old 07-31-2004, 10:30 PM   #1
jorgensensc
jorgensensc's Avatar
My wiring started frying?!?!?!?
Yesterday I left my lights on when I got home and realized it last night. My battery was dead. I decided to jump it off a battery that I took out of the MG that was still good. I got it all hooked up and went to go start it, but before I could do it I heard a popping noise and saw smoke. I went around to the engine and there was smoke coming from the battery and the fusible link by the battery was GLOWING RED. I unhooked the cables (they weren't even hot) and rechecked my connections. They all appeared good. I hooked it up again, and it started smoking. Needless to say I was freaking out. WTF?! Well I reluctantly went and got the wifes car and decided to jump the truck off it and pray it didn't fry her electrical. I hooked it up and the truck started right up! I figure something must have been wrong with the other battery. Do you suppose that beause th MG was wired Positive to ground that it screwed something up in the battery? The fusible link didn't break connection, it just got glowing hot. I still can't figurre out what happened. No other fuse blew and everythng else works fine. The fuses for the ammeter didn't even blw. I'm seriously confused.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-31-2004, 10:45 PM   #2
fast71
Drive it like U stole it
fast71's Avatar
sounds like the battery shorted out or it had reversed polarity.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 07-31-2004, 10:54 PM   #3
jorgensensc
Must have been reverse polarity since the battery came out of the MG and it was wired for Positive to ground. Crazy ass British Electrical! (No offense to any Britains on the board)
