Old 08-01-2004, 12:41 AM   #1
69 Short Fleet
Angry I've Had It (charging System!!!!!)
W T F is going on here!!!!!!! My battery keeps draining, I just bought and installed
- New Bosch 55 amp alt.
- New external voltage reg.
- New pos. battery cable
- New neg. battery cable
- New alt. belt
- New yellow top Optima battery (12.6 volts)
- New points
- New condenser
- New cap & 8mm plug wires
EVERYTHING is grounded PROPERLY! I pulled the neg. cable to see if there was any voltage between the terminal and the cable and NOTHING!!! (no shorts) I have almost had it with this problem as this is the third time in a row the pig has acted up, the only thing I can think of is getting the battery tested at the shop where I bought it. I should also mention that some "Pillar Of The Community" Vandalized some of my elec system when it was in storage during my resto, but all I could find was a cut off alt. connector (which I already repaired) and a couple of plug wires cut (which I already replaced) I really could use any and all ideas here. Thanks Doug
69 Short Fleet is offline   Reply With Quote
Old 08-01-2004, 12:53 AM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
See if anything is stuck in the on position, i.e headlights / wiper / lighter (not sure if our trucks came with them, mine doesnt have one).
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 08-01-2004, 01:29 AM   #3
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
If you're not getting ANY draw when you put a meter between the neg cable and the net post then it (almost) has to be the battery. How fast is it draining?
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 08-01-2004, 01:41 AM   #4
Martin64
Martin64's Avatar
For me it was the horn relay that was staying open.....just enough to drain the battery in about 2 1/2 days
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 08-01-2004, 04:25 AM   #5
69 Short Fleet
I went for a drive for @ 45 min. and just before I left I had 12.6 volts (engine off) at the battery and it flashed right up, I checked the voltage again at the battery (engine running) and it was the same 12.6 volts. So it would lead me to believe that the charging sys. is not working as it should be around 14 or 15 volts. As I went for my drive I was watching everything (battery gauge, headlight, taillight brightness, dome light brightness, turn signal speed, ect.) like a hawk, and noticed after @ 20 - 30 min. the turn signal speed was slower and my lighting sys. was dimmer so I headed for home and when I got home I shut the truck off and tried to start it again and nothing (starter was silent). A few days ago (the first time it acted up) I was driving along and noticed I hardly had any headlights and then the engine started to run really bad so I immediatley shut the headlights off and the truck ran normal again. I'm so PO right now, I don't know maybe my new alt. whoooped right from the factory? Doug
Old 08-01-2004, 04:43 AM   #6
67cst
i love summertime
67cst's Avatar
hey doug, thats a major bummer with the truck, i wish i knew what to say, i hate wiring problems....so you replaced that alternator? are you going to buff the new one up? or put the old one back on when you find the problem
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 08-01-2004, 05:36 AM   #7
69 Short Fleet
Hi Derek: Ya I'm going to keep the new alt. on as it has more amps but I'm not gonna polish it (the old one took crazy hours to do). I was at Wards Elec. (just off of Springfield) the other day and they had a 100amp (one wire) Powermaster (chrome one) I almost bought, it was $200 (not too bad) and the plating on it is really nice but decided to go with a Bosch 55 amp from Lordco $75 with my discount. Stop by on the weekend if you can, Regards Doug
Old 08-01-2004, 08:55 AM   #8
racedvl
racedvl's Avatar
If you bought a bosch alt, chances are it is junk. . . . .
I work at a jobber supplier that used to sell Bosch electrical units, but we dropped then all together because the defective rate through the roof!!!!!
racedvl is offline   Reply With Quote
Old 08-01-2004, 11:11 AM   #9
chevman-67
chevman-67's Avatar
have you thought about changing to an internal alt.I did and i dont regret it. Seems i have better power in my charging system, brighter lights nothing dims down anymore when i come to a stop. I have a 105 amp and it runs my truck my neons underneathand my sony explode deck and amp all with ease.unless you want to keep stock i would change. only my thoughts. if you need info just ask.by the way check and make sure all your insulators are on your regulator on the rad support they are notorious for rotting off.
gm's are #1
1967 chevrolet short step
1988 chev 4x4 1/2 ton
1989 gmc 1/2 ton
1991 chev 1/2 ton 4x4
1993 Jeep grand cherokee 4x4
And yes a 94 Ford Mustang.
chevman-67 is offline   Reply With Quote
Old 08-01-2004, 11:29 AM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have to agree with the last two statements, Bosh alt never seem to work. (NAPA ones are just as bad...brobably the same maker)
I would swap over to a later model int reg unit, more amps even with the smaller 64 amp unit, better charging, and less headache.
Personally, i say stay away from the one wire units, they have some draw backs that most ppl don't talk about including cost, parts avalability, and pully ratio/rev issues.
Old 08-01-2004, 01:20 PM   #11
stllookn
Saving 1 truck at a time!
stllookn's Avatar
You have it right on the bad alternator if you are not getting 14.5 on the battery after start. It could be the excite wire to the alternator that is bad. I bought a truck (that had been vandalized) that had the same problem...battery dying after a short period of time. The price was really low and I could not figure out why until the second time the battery died without provocation. I traced the problem to the loose wire on the ignition switch that provides 12v. to the alternator excite field. Solved the problem without and expense and then realized why the price was so low...he could not figure it out and never mentioned it when I bought the vehicle. I think he thought it had demons or something. I wished I had run into him again just so I could tell him what a great deal he gave me...full disclosure is usually best!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-01-2004, 02:41 PM   #12
69 Short Fleet
racedvl - Interesting about Bosch, I thought they made decent stuff, my bro used to have a few Porsches and they had Bosch componets (it sounds like the company has gone downhill) back in the 70's, 80"s
chevyman-67 - I'm not concerned about keeping my truck stock as it is not a factory restortation. I will be adding a couple of stereo amps (Pioneer) later on so I'm thinking I should have at least a 100 amp anyway.
- Andy, your Back!!! AWESOME!!! What year of truck is the alt. your talking about and should I maybe look at a Delco...
- stllookin, Yes I know what you mean about some people not coming clean when there selling ... I bought a dragbike once that loved to eat camshafts and the owner "forgot" to mention it. (bonehead) What color is the exciter wire that goes to the ignition (just so I'm clear on it)
Thanks for all your input this helps!!! Doug
Old 08-01-2004, 03:08 PM   #13
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I'm running the original Delco Remy alternator on mine and the only problem I've had was the voltage regulator going bad, might replace that if yours is an external regulated alternator.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-03-2004, 09:40 PM   #14
srosa707
IM havin the same damn problem, i cant fuigure it out either... let me know how you end up solving this one...
srosa707 is offline   Reply With Quote
Old 08-03-2004, 10:16 PM   #15
69 Short Fleet
This problem will just not go away! I go back to the parts store and return the new alternator for another new alt. and the 2nd alt. is not putting out either!!! So I triple check the voltage and it is 12.15 volts at the battery and at the alternator, should be enough voltage you would think right? WRONG, WRONG, WRONG!!!!! I just brought my battery back to where I bought it and 12.15 volts is @ 40 % of the battery's capacity!!! This is how DC voltage on the battery works
12.60 DCV = 100 % Charge
12.40 DCV = 75 % Charge
12.20 DCV = 50 % Charge
12.00 DCV = 25 % Charge
What I think is going on is the charging system is working fine it is just that the BATTERY VOLTAGE (at 12.15 volts) is too low for the charging system. So I will pick up my battery tommorow afternoon (charged up to 12.6 volts) and install it and post how I made out. Another thing I've learned about Optima is they like to be in a cold enviroment (I pulled mine and stored it inside the house for the winter). Doug
Old 08-06-2004, 12:29 AM   #16
kbs71
71 rustless in texas
kbs71's Avatar
Alright guys I had this same problem and it's usually the external voltage regulator. The "buzzer" points system is really antiquated and it seems that everyone making them now days is junk. It senses low voltage from a "buss" location (4 red wires and a brown one soldered together at the left front fender area in the harness), and has the altenator put out 14.7 volts to charge the battery. Sometimes the points stick or weld themselves together and the altenator won't charge. If you replaced your altenator and still having the same problems open up the regulator and check the points. You'll probably find them welded together with a little ball of metal. you can file this off and it will start working again, BUT I guarentee that it will happen again. I bought a internally regulated CS12 altenator (96amp from auto zone $69.00) and a mod kit from www.madelectrical.com for @ $24.00. The guy Mike really knows his stuff. His web site is full of some really informative articals about the charging systems on older GM cars/trucks.
After installing his kit, which took me @ 2 hrs. to fab up and another 4 hrs to install (I'm kinda a perfectionist). I have not had a single problem with my charging system. Where before I was constantly getting stranded.
Anyway check it out his prices are reasonable and he has a lot of neat parts, and he will be glad to discuss anything over the phone and he gives expert advise.
kbs71 is offline   Reply With Quote
Old 08-06-2004, 06:42 AM   #17
JimKshortstep4x4
Smile
69 Short Fleet,
I know you said that everything is grounded but I would still check to make sure the external regulator has good ground, (check the regulator case to the negative battery post). Should read less than .5 ohms. Also, check the voltage of the exciter wire with the engine off and the engine running to make sure you have voltage there.
Jim
Old 08-06-2004, 10:13 AM   #18
72CheyenneRY
join the club
I burned through four sets of alternators/regulators/batteries until I changed over to an internal regulator. I also had an arc in the power lead to the starter that was slapping the block/header (while moving - no problems sitting still!) and shorting out the regulator. I completely feel your pain!!
72CheyenneRY is offline   Reply With Quote
Old 08-06-2004, 11:41 AM   #19
Blue68
Blue68's Avatar
Remember guys, don't hook a new alternator up to a dead battery. It'll kill the alternator. They can't charge a dead battery. Charge the battery with a charger first. If it won't hold that charge then obviously the battery is dead.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
