Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 08-01-2004, 08:17 PM   #1
soonerfan39
Lunati hydraulic roller camshaft
I bought this cam off of Ebay. It is brand new still in the box. The problem is that it won't work for me. I got in to big of a hurry and didn't notice that it was for the 87-present blocks. If anyone is building a newer roller motor this cam would be a steal. 110.00 plus shipping. The cam sells from Lunati for 325.00
Thanks,
Kevin
soonerfan39 is offline   Reply With Quote
Old 08-02-2004, 09:42 PM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Just curious what is the specs and also what is the difference in the 87+ blocks?
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 08-02-2004, 11:02 PM   #3
soonerfan39
Lunati cam
It will be easier if you will go to this link and look up the part number of the cam for the specs. http://www.lunaticams.com/ I'm not sure what the differences are in the blocks, but there must be something or else they wouldn't list them seperately.
thanks,
Kevin
Old 08-02-2004, 11:05 PM   #4
soonerfan39
Lunati cam
Crap forgot to give you the part number! 54762 is the cam part number
Old 08-03-2004, 09:33 AM   #5
patgizz
patgizz's Avatar
newer blocks have provisions for factory roller cams, so this one is probably a factory style with a smaller bolt circle on the timing gear, and made for the factory front cam retainer plate, which the older blocks dont have the machining for.
i dont see why it couldnt be used though in an older block if you use the correct timing set and use a thrust button on a good solid(not stamped steel) timing cover like a regular roller cam retrofit.
patgizz is offline   Reply With Quote
Old 08-04-2004, 11:58 AM   #6
79BIG10
79BIG10's Avatar
Wow that's a big cam. Too much for my application. If I had a better set of heads it would work great.
Old 08-04-2004, 07:39 PM   #7
73stepside
73stepside's Avatar
that's a roller cam
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
