Happy to be here
![]() Join Date: Mar 2000
What did you get done?
It's time for our Sunday evening feature of "What did you get done?" This week/weekend I got NOTHING done. I worked all weekend so nothing got done on my truck(s). I planned to wash my 02 GMC and get pics so I could put it on traderonline.com but it rained all afternoon....
![]() I need to get it sold so I can make rooom for something else.... ![]()
around the house: got new pea gravel laid down for the dog so she isnt laying in mud
on the burb: my buddy just dropped off the exhaust : headers, 2 catco cats, 2 cherry bomb turbo mufflers, balance tube kit, and dynomax dual exhaust kit. got called by machine shop, my block needed bored, so it needs new pistons, so i need to pay them more than i was hoping to. on the lumina: dropped my new low mile 3400 in and got it almost all hooked up. ![]() polished the grille and front bumper on the caddy: ![]() |
Slots go on anything!
I actually worked all weekend on my Blazer. I drove it to work on Saturday, and heard a weird grinding sound. I ended up doing teh rear brakes, as they were nearly to metal. I left the top at work
1974 Jimmy- 5.3/4L80e/NP241 |
#4 | |
Happy to be here
#5 | |
yeller
That is all I can think of right now, Jonboy will add some I am sure. Also, what gears do you have out back now Ken?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#6 | ||
Happy to be here
![]() Quote:
DAMN, I love Big Blocks!
Not a damn thing, unless you count sitting home nursing a herniated disc in my back!
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() |
I got lucky and robbed everything from the 82 Blazer I had. Do you have the long tailshaft 350 in your truck right now? I had one in the blazer, and ended up using teh original crossmember and mount. The 700 driveshaft was about 1" shorter. I swapped the columns, as the 82 had tilt, and the shifter has a different detent to downshift to first. I used the TV and accelerator cable bracket from the 82, but an aftermarket one will work as well. I also used the Painless wiring kit before I saw the instructions on Jeff's site. My truck already had the shift indicator with the OD lettering, the 82 said "Automatic Overdrive" above the letters. I went ahead and added a Summit trans cooler as well for good measure.
A couple points of interest: GM changed the trans dipstick tubes in later production units (90 or so?). They went to a boot seal and a locking dipstick instead of the o-ring seal. I think these transmissions would boil the fluid and spit it on the converter. which is right below the dipstick tube. I had an 89 'burb burn to the ground because of this. The other thing is the 700 seems a lot bigger around than a 350. It is a royal PITA to connect the cooler lines fro some reason. I had to fight mine to the point of wondering if 700's have a metric thread. They do not. Patience won out, finally. That is all I can think of, off the top of my head. Once the trans was bolted in, everything went pretty easy. I had a dual pattern flexplate (I think most small blocks do) and the speedo cable was the same. Mine seems to be super long, as someone bypassed the factory cruise.
lets seeeee.......saturday me and the wife went garage selling. spent $11 and got my daughter a bike, 21 books, and 2 puzzles. nothing for us though. we got training wheels and put them on and put the BBQ grille together finally.
sunday i worked 12hrs and then taught my daughter to ride her bike...... |
ok i have a couple of question on the 700 swap, first, whats wrong with a toggle switch to manual lock up and unlock the tq when ever you feel like it? thats the best and easyest way for me. my truck came with a 700 and it didn't have anything but the main harness up to the firewall were it just stoped, i dunno what the crap happend to it, oh well toggle switch! but maybe thats just me. oh! and i also have a drive shaft for a 700 long box, not shure on shipping it if anyone is a long boxer...anywho, i killed my 2nd transmission case!!! so im sorta glad about that actually the last 700 was a pos and had something internally wrong with it. so we order all of our parts for it from wwww.balkpart.com cheap stuff i must say, and well i got bored on saterday so then i went to town and pulled my bench out, and my carpet and fixed my brothers sub box for my 2 12s. and i also installed my battery box in the back. tomo is going to do all of the wiring i can while i wait for my distribution block and inline fuse to come in. ah gotta love not being able to by anything from a store.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
The main reason I didn't want a toggle switch tor the lockup is that I forget. Drive a late 90's Suburban with the converter that stays engaged and you will see what I am saying. I would forget and leave it locked in, and the engine would die at stoplights.
Happy to be here
Yeah me too. I can't get used to not having auto headlights since all my newer trucks have it. I know I wouldn't remember to lock/unlock the convertor. Besides that just not me....
#13 | |
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
#14 |
that and with the big block when u give it to much...new tq! i see now
#15 |
california fill
bowtie's 700's give you a toggle switch to manually lock them up but they also lock up themselves.. I didnt know it was possible for the converter to lock in 1st gear. Even if you do just the toggle switch idea, you should route it thru the brake light switch so it unlocks when you brake.
pc |
#16 |
driving is in my blood
I just got finished, had to wait all day till my hangover went away
![]() I pulled my intake manifold off the 79 and re-set the valves using the IC-EO method one cylinder at a time. Also putting new intake and carb gaskets on. Im trying to fix the crappy idle and part throttle running of the engine, it sucks right now. Stumbles and kicks a little bit every time I just start on the gas.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#17 |
Under construction!
Spent a few hours prepping the upper and lower controls arms to be powder coated. I also ordered another PST front-end kit.
2001 Silverado bagged on 22's. *Sold* |
#18 |
Put my door locks back in,
now I just have to find the key or I am in trouble ![]() |
#19 |
Well, my 'project' truck isn't going to be anything special or a daily driver, just a second vehicle, going mainly stock. It's finally running with a freshly rebuilt 305 and a 700r4 I got out of a Suburban. Runs and drives fine, needs more work to pass inspection and get tags. Saturday I got a used exhasut system from a guy here on the board that came off a 92. Will have to take it all apart and re do it to make it work on my 84, but it has a big pancake like catalytic converter, a Flowmaster muffler (18" long), anxious to hear it) and chrome tips. Yesterday turned into 'window' day. The truck had tinted windows on the doors and sliding back glass that had turned purple and had wrinkles all in it. I took off all the tint and cleaned the glass. Then the passenger window had a spot where it would hang on the way down (power windows) Simple fix, the bottom rail attached to the glass needed to be bent slightly on one corner. The driver door window was stuck in the up position. Found that two of the four bolts holding the power assembly in had come out and the whole assembly was shifted out of place. Had to pull the armature out of the window motor and clean it and the brushes up to get enough 'umph' out of it to lower the window and unlodge the whole set up, line everything up and bolt it back like it goes. Driver window works now, but goes slow. With no AC working yet, got to have the windows working here in SE Texas (even though it has nothing to do with getting the emission stuff finished so I can get inspected). Man it sucks working on power windows.
Paul 1984 Chevy C-10 *LWB/305* |
#20 |
I was able to sell the rear axle out from under my old parts truck. This is the one I have been unsuccessful in giving away the last several weeks. The second guy that called bought it and didn't even haggle on the price.
All I need to do now is get the stupid thing cut loose. |
#21 |
Signals in the bumper.
Bought and installed 20's.
![]() Oh, and I ordered a billet grill.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link Last edited by bagged81; 08-02-2004 at 11:50 AM. |
#22 | |
yeller
#23 | |
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
#24 |
Insert Witty Text Here
I flushed my A/C system and put in a new (not rebuilt) compressor and replaced the orifice tube. I got it vacuumed down and filled last night, but it isn't as cold as I would like it. I'll have to see if I can get some more R134 into it.
It feels good to be working on the truck again. I have been unable to walk for the last 2 months after a couple of surgeries on my ankle, and I'm just starting to get around again. Everything went to hell during that time, of course, so I have a lot of work ahead of me this Fall... Slonaker |
#25 | |
