08-02-2004, 08:50 AM | #1 |
What year were the long Spark Plug wires?
I bought new wires for the truck yesterday and 3 were too short. I seem to remember a thread that discussed which year vehicle to get plug wires for so they would be long enough. I thought it was an older corvette, but I'm not sure. I thought someone was using the wire splitters that connected to the block at the back and they said a certain year corvette had the correct length wires. i'm just looking for anything that would be long enogh. 60.00 for wires to get fried on the manifold isn't going to work. Any help would be greatly appreciated.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
08-02-2004, 09:48 AM | #2 |
Mike
Ithink it is the 70's small block vettes.Up to 73 for points and74 and newer for hei.I but Taylor wires from summit and cut them at what lenth I want.They are good wires and come in colors others don't have.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
08-02-2004, 09:53 AM | #3 |
Resident Curmudgeon
Depends on whether you have HEI or not. No HEI, get the stock wires for a 67-72 truck smallblock. HEI, get 75 vette wires. here are the vette wires using HEI on a stock ramhorn equipped smallblock
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
08-02-2004, 10:00 AM | #4 |
perfect!! thanks guys, i knew I could count on you to come through for me. i'm a little afraid of screwing up the wires if I try and do them myself. 75 vette it is!!!
08-02-2004, 11:37 AM | #5 |
The oddest Todd around
75 vette. Thank you. That helps me out tremedously as well.
Todd |
08-02-2004, 10:55 PM | #6 |
"Ochre Ogre"
Isn't it a shame that Jeff(CPNE) doesn't remember how to run his wires the "stock" way. Let's ask the judges..........yep, they all say that qualifies as a custom modification. Let's just hope that picture is a stock photo and not one of Jeff's engines.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
08-02-2004, 11:21 PM | #7 |
I just did a conversion to HEI and the GM part # for the delco wires is 12043740. I always run the wires on top of the valve covers and curl them around the cyl heads.
08-02-2004, 11:22 PM | #8 |
Well, what is the stock way? I want to see because I plan on doing the stock wire thing shorty myself!
thanks |
08-03-2004, 08:38 AM | #9 |
I just got the Accel part # 4041 for my truck. They are 8mm (I wanted 8.8mm, but they had to order them and I didn't have time to wait for them). I had to put my own boots on the ends (what a pain in the a$$) , but they look great and were plenty long enough!! I was able to route them all down behind the back of the block ( like the pick above) using the wire loom attached to the back of my block on both sides. I also used the looms included and they look really good. My old wires ran over the valve covers, but I kinda dig the way this really cleans up the engine. The engine looks less cluttered now, and that's hard to do with A.C. hoses and all the other hoses, and you can see the shiney valve covers now. Thanks again CPNE!
Shawn
08-03-2004, 09:21 AM | #10 | |
Resident Curmudgeon
08-03-2004, 03:13 PM | #11 |
Ok, i just did this last night. I have HEI and I hate the angle plugs, especially with my ram horns. I bought plugs for a 76 Pickup with a 454. They have the straight boots on the plug ends and are more than long enough.
The best part, is that they are only $15.99 with a lifetime warranty at Autozone.
Just sitting here contemplating contemplation. Last edited by 68 Suburban; 08-03-2004 at 03:17 PM. |
08-03-2004, 03:28 PM | #12 |
Here are how mine are routed with the HEI using all the original shielding, clips & etc
08-03-2004, 03:50 PM | #13 |
Dean
Thats a nice setup. Is that all stock? |
08-03-2004, 08:10 PM | #14 |
"Ochre Ogre"
Jeff, the way I have seen has the wires in a clip on the oil pan rail and the 1,3 and the #2, 4 wires actually run between the block and the motormount on their way up to the plugs. And yes, the back wire holders are indeed correct. I was just funnin' you for the routing of the front pairs of wires. It looks like Dean has his the way I know of.
08-03-2004, 11:33 PM | #15 |
Ok, so what is the correct wires to use on an HEI setup with hooker long tube headers? Does anybody have any pics of the correct way to wire those up as well?
08-04-2004, 06:51 AM | #16 |
Yes, my routing is pretty much stock and it is a pain to get the wires between the motor mount and the block. You really need to pull the mount off or the wire boot off to get it thru there.
