Heater Blower motor always on
Hi,
I recently purchased a 1982 GMC 7000 (5 ton dump and 4ton HIAB crane). The interior is pretty much the same as a regular GMC pickup. The blower motor connector was disconnected, after I hooked it back up I found out why ![]() thanks. greg |
Slots go on anything!
the fan switch on the dash may be shorted out. Try unplugging it with the blower connected and see if it stops.
1974 Jimmy- 5.3/4L80e/NP241 |
That is the way they all are it always runs most people unplug it in summer. I ran a toggle switch to mine so I can switch it off and on. As far as I Know all the chevys are that way at least all the ones I have ever seen.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Garage Queen Material
its to help keep fresh air circulated since these trucks have such "great" cab sealing.
they thought we would suffocate without air coming in hahahah |
#5 | |
Could you give some instructions on wiring that toggle switch? I noticed mine did that and thought it was messed up. I was gonna start a thread but was too lazy. ![]() I'd like to shut that sucker off. It's annoying to turn the key and hear it (mine needs replacement i think cause it sounds pretty worn out.) |
The wire the you pull out from the motor in the engine compartment I just cut it and ran a switch into the cab.
#7 | |
Eric is correct on this one ![]() ![]()
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
Tonawanda 454
i seem to have the problem of it NEVER coming on, even with a new blower motor... no matter where the switches are set to its never on.. it used to work (but only through the floor vents, it never moved from there).
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
#9 | |
whats up with the laugh???? you think i'm a tard or something??? ![]() |
#10 | |
You get what you pay for
![]() Join Date: Dec 1999
Mike 1985 Chevy C-10 |
LED King
My blower motor isn't always on. Am I missing something here? GM did make a "flow through" cab - if you are moving, air is pushed through the front cowl through the floor vent to the vents in the bottoms of the doors. That is why there are vents in the bottom of the doors.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
#12 | |
No implications whatsoever... ![]()
#13 |
Right turn Clyde
My truck blower turns off If I turn it off. Had a 78 Coupe Deville that always ran if the key was on.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#14 |
I think the A/C-equipped GM vehicles had them run all the time so the A/C wouldn't ice up. Or maybe so they would wear out faster & they could sell you a new one.
#15 |
![]() Join Date: Feb 2004
Mine's always on in my '76. It used to blow out the regular vents until I changed out my heater core, and now it blows out the floor vents. I don't know what I changed, but it must have been something.
![]() Mike ![]() |
#16 |
Thanks for the replys. Sounds like it may function that way.
#17 |
My '77 (non-A/C) was an "always on" set-up. My '86, A/C truck actually turns off.
Funny, I'm not suffocating ![]() ![]() ![]() ![]() |
#18 | |
Yup, my '86 is the same way. The blower is off when the switch is off. Both the motor and the switch/control assembly have been replaced over the last 6 years. It's always been like this. Now, you do get some flow-through ventilation at speed, but not from the blower motor.
Semper Paratus |
#19 |
www.73-87chevytrucks.com
The fan switch is set to be "always on" for the non-A/C trucks. A/C trucks you can turn the fan off.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#20 |
OutOfMyMind & I'llNeverKnowWhy
The fan is always on on my 76 with factory A/C. Rather annoying to say the least. I even replaced the relays. Off means off!
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
#21 |
Professional Grade
I haven't had my heater fan hooked up for a long time now, but my heater and defroster still work just fine. Just takes a bit longer, hehe
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
